EM TuningMonster Motorsport
    Sep 2012
    16
    2.0 TDI 140BHP- Possible DPF Fault?
    Hi All,
    Before we start I have an Audi!!!
    My partner has a VW EOS 2.0 TDI which is the same engine as a golf and later A3's I think?
    The other day my partner was driving to work and the car was driving as normal, then all of a sudden the car just cut out (lost power) revs dropped as well as mph???
    She took her foot off the accelerator and put it back down and it worked as it should. I took it for a drive after work and no issue. We were driving on the motorway today and it happened again??? very serious and very dangerous as we have 2 young children. She took her foot off the accelerator and planted it again and hey presto it worked as it should?
    There was no engine management light on and fuel consumption etc is as normal?
    Today the engine management light came on so I took it to an Indie immediately!
    The codes were as follows:
    09299 - D.P.F pressure sensor (P2453) Implausible Signal
    01137 -Exhaust Pressure Sensor
    Although I was informed the D.P.F can cause the Exhaust Pressure Code?
    My main concern is that a D.P.F failure doesn't usually cause such a severe outcome or does it???
    Any Suggestions
    27,121
    If the dpf sensor has failed, it could very well cause issues of bad running, given how clogged dpf's affect these engines, get the sensor resolved & I hazard a guess it will right itself afterwards.
    Sep 2012
    16
    DPF
    Hi,
    Are you advising me to get the Exhaust Pressure Sensor done?
    The mechanic was saying its the DPF that can cause the exhaust pressure sensor fault code?
    And do DPF's have a sensor or is it a new DPF needed?
    Sorry for my naivety
    27,121
    I should of been clearer, when I say get resolved, meaning check the whole dpf system for things like soot levels, regeneration, dpf clogged & unusable, sensor remove/replacement, variety of things to check for sure.
  1. Possible Flywheel Fault - TDI DSG
    By TDIDSG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th October 2009, 00:41
  2. Buying a A3 TDI 2.0 - Common Faults?
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2009, 12:15
  3. 170 TDI Glow Plug Relay Fault
    By PJLarge in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2007, 08:22
  4. Please Help (Possible electrical fault) A4 :(
    By a4TDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2006, 22:08
  5. Engine Problem - 2.6 V6 - possibly ECU Fault -
    By imported_k15hvc in forum Classic Audi Forum
    Last Post: 11th July 2004, 21:40
