Volks AutosChris Nott
    210_MIH's Avatar
    Drive it like u stole it
    May 2012
    103
    RNSE Bluetooth Problem
    Hi All
    Everytime I connect my phone via bluetooth, it disconnects after like a minute, then re connects. The annoying thing is when this happens during a call - disconnects, then spends 30 seconds to re connect!
    Anyone know what needs to be done to sort this out?
    thanks
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    First you need to find out if the problem lies with the Bluetooth module or the phone.
    Connect another phone to it, does the same happen?
    If it does, I'd first go about replacing the Bluetooth antenna to see if that fixes the issue. If not, then possibly a replacement bluetooth module.
    VCDS scan wouldn't hurt either.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    JRock247's Avatar
    Jul 2012
    Hampshire
    340
    What phone are you using?
    Might want to also check if your phone has any available updates to its operating system and also the RNS-E software for any updates, may resolve Bluetooth issues with phone/RNS-E
    Do you have VCDS? Check the VCDS map on here, shows you were local VCDS owners are near you.
    Ask admin to advertise here
    27,105
    Quote Originally Posted by 210_MIH View Post
    Hi All
    thanks
    Remove the pair, disable BT, then restart handset & the car, then re-enable BT on handset & repair handset & let it sync contacts then test.
    If this fails to work, then 1st question to ask is, which handset are you using, IOS & Droid both have issues with BT modules of varying years, then you have to ask which version BT module is fitted, then you need to look at updates to both systems, handset & car.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I've had 5 different phones in the time I have had my car and they all responded differently to each other which trying to connect to BT. The two worst were both Android phones.
    8P2 S3
  1. Bizare RNSE/Bluetooth problem
    By stucker in forum Satellite Navigation
    Last Post: 13th December 2011, 20:42
  2. Rnse Bluetooth and sds problem?????????
    By Craig1989 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th December 2011, 19:31
  3. Got the new S3 - Bluetooth Problem
    By L33TAY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2008, 17:45
  4. Bluetooth problems
    By GeoffT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2008, 18:40
  5. Bluetooth Problems
    By Badley in forum In-Car Entertainment
    Last Post: 23rd June 2007, 12:19
