Monster MotorsportEM Tuning
Results 1 to 24 of 24
Like Tree2Likes
  • 1 Post By crunchie
  • 1 Post By The Governor
Thread: Quattro Tyres
    buttons89's Avatar
    May 2013
    Aberdeen
    17
    Quattro Tyres
    Hello!
    For my first post I'm probably about to kick up what seems to be an ongoing uncertainty around Audi forums!
    Got myself a MY10 A3 Sportback 170PS 2.0tdi quattro BE just over a month ago and I've just noticed these cracks on both rear tyres on the tread/sidewall transition and circumferentially on the inside tread groove. Running Bridgestone Potenza RE050A 225/40/R18 92Y. I am uncertain of the tyre usage from the previous owner or what comes as standard on these models, however the car was barely used by the previous owner (12k miles when I received it).
    Wondering what people's thoughts are on this, advice with changing tyres on quattro systems with regards to changing axle pair/all 4 corners, different brands front/back, recommended tyres? Will probably be going to a local tyre shop to get a quote at the weekend
    Any help will be much appreciated. Will hopefully get round to a happier hello post with some nice pictures in the near future!
    P.S. Very good forum.
    boost-addict's Avatar
    Aug 2011
    977
    welcome to the forum, tyres crack like that with age, there are date stamps on the tyre as follows
    Tire Tech Information - Determining the Age of a Tire
    just get them changed, you've said your self the car has had little use, and the tyres have clearly been on much longer then the tread would have lasted if they were in constant use. ive seen worse but its a mot failure as far as I understand.
    this isn't a common problem to this car or any per-se, just a common problem for tyres as a whole.
    just change all four as there all old by looks of it
    edit, looking at the pictures, the tyres were manufactured week o of 1990. so the tyres are 13 years old.
    27,094
    Contact Bridgestone with photos & see what they say.
    I use Vredestein Sessanta's atm, good on wet & dry, the latest versions are called Vorte's iirc.
    buttons89's Avatar
    May 2013
    Aberdeen
    17
    Definitely changing then!
    27,094
    Quote Originally Posted by boost-addict View Post
    Think you mean 23 years old, which would maybe explain why they have gone this way, but I cant see it somehow on a 2010 car, I doubt it.
    Oct 2012
    139
    Quote Originally Posted by buttons89 View Post
    You are supposed to change tyres per axle on the A3.
    However I had my car MOT'd today and my 2 front tyres are on different wear rates (1mm difference). As both were replaced at the same time I think we can assume a few mm out on each tyre isn't going to be a problem!
    Jan 2012
    West Cornwall
    37
    That's not the date stamp in the pictures, is usually just 4 numbers and nothing else.
    My friend had the same problem with Bridgestones fitted to the rear of his Honda Accord, less than 3 years old & cracking very bad.
    Aug 2011
    977
    could be part worns or what ever that were put on it, who knows. any thing is posible.
    the date stamp is there right next to the dot stamp
    unless thats the 9th week of 00 which i guess would match up to the cars age.
    i guess if it hasnt had use it can crack up from no heat cycles
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Looks like week 40 2009 to me :-/
    Do you seriously think they made Potenza RE050's in 1990
    They will be the originals, just get them changed out for peace of mind.
    I wouldn't want to go any further than the shops with them on tbh.
    NHN likes this.
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Aug 2011
    977
    possible, i didnt look what tyres they were. so bang ya head all you want
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    What the mileage on the car as they may be the originals as those tyres were fitted at the factory from new in 2010....
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Aug 2011
    977
    Hello!
    Quote Originally Posted by audicruiser View Post
    12k miles
    Oct 2012
    139
    I used to know someone who said certain tyre dressings were really bad for the rubber. May or may not be true.
    We used to have a Jag with 30 year old tyres on it. Car had only done 18k and only failed on the tyres when one of them ruptured. Go figure!
    Aug 2011
    977
    that just depends mate, was this jag kept in a garage?
    buttons89's Avatar
    May 2013
    Aberdeen
    17
    Thanks for the replies. There has been a tyre change at some point as the fronts are newer and in better nick, DOT codes 4611 and 3012.
    Any more thoughts on recommended tyres etc?
    Oct 2012
    139
    Garaged up. In retrospect it seemed stupid to keep tyres that old but in those days you didn't question it unless it failed an MOT.
    Aug 2011
    977
    then the tyres wouldnt be susceptible to frost
    and i wouldn't be surprised if it was a heated garage too
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    I don't know but I was told by the lads that do the tyre changing for Audi near where I live that if there is a 1mm difference front to back with the A3 quattro system then you should replace all four so the Haldex isn't being abused and running when it's not actually required.
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    buttons89's Avatar
    May 2013
    Aberdeen
    17
    Daggerit, notice you are in Aberdeen too. Who do you recommend round here for tyres?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    perhaps used on track day event.
    Oct 2012
    139
    Quote Originally Posted by Daggerit View Post
    Sounds like a nice little earner for them. "Yeah guv, you'll need 4 new tyres rather the 1 you came in for".
    buttons89's Avatar
    May 2013
    Aberdeen
    17
    So after a phone call or two to the dealer, the end result...two new tyres on the back (same Bridgestones) courtesy of the dealer, who also collected and dropped off at work. Only complaint was getting a wee VW Up courtesy car after requesting a larger car! So I've got some extra pennies for a beer or two thanks for your advice! Will hopefully get the car cleaned at the weekend after ordering a bunch of Dodo Juice products and post a few photos.
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Quote Originally Posted by chinnyhill10 View Post
    I imagine they say that while relentlessly pounding your arse.
    Unless you're driving at the limits of grip, I can't imagine the Haldex being affected at all really... I'm going to be swapping my fronts before my rears, at least according to current wear rates, and I won't be letting the tyre fitters spit-roast me in the process :D
    autolatry likes this.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Not really because I was on the Audi complete package so they were essentially paying for them on that occasion. Putting two on would've saved them spending as much money, hence the reason I believe it.
    The reason I looked at the tyres and took it in originally was because I could feel like the FWD was coming on and off which is apparently a symptom...
  1. quattro & Tyres
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2007, 19:06
  2. Quattro Tyre Wear.
    By johnmv55 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2007, 09:40
  3. 1.8T QUATTRO TYRES
    By busboyt2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th February 2007, 22:32
  4. Quattro tyre question
    By eimajmong in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2006, 00:32
  5. 1.9 tdi quattro tyres
    Last Post: 12th October 2005, 19:28
Tags for this Thread
