Sky InsuranceChris Nott
Results 1 to 10 of 10
    Mar 2013
    21
    Tfsi h&r springs on a tdi
    Quick question, might be a daft one.
    A mate has some h&r springs off his s line tfsi will they fit my s line tdi or are they different due to the heavier Diesel engine?
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Check H&R's website for the part number of the springs for both models, and if they are different then I wouldn't do it.
    TDI140's Avatar
    May 2011
    1,350
    Both had 55mm struts if they at both 2.0tdi and 2.0tfsi but check website as ADS has said
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Mar 2013
    21
    Cheers chaps I've had a look at a few H&R suppliers websites and they seem to just offer one package for the whole 8p range so i'm assuming they will fit based on that?
    Jul 2010
    Merthyr Tydfil, United Kingdom
    881
    Springs should be model specific. The TDI engine is a fair bit heavier than the TFSI!! You may find that the TFSI springs are too bouncy
    physically they will fit
    i stand to be corrected but on my last car I had to make sure the springs were for the TDI model
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by Henry1302 View Post
    That's not correct as H&R must offer different springs as the weights involved are different... i.e. Quattro, FWD, engine sizes.
    Don't take what the suppliers say as gospel, visit H&R's website for the proper info.
    Mar 2013
    21
    Ok had a look on H&R and they do seem to bundle them in together, i.e 2wd, 4cyl and tdi: Audi || Suspension Applications || H&R Special Springs, LP.
    Mar 2013
    21
    I've just had a look on the parkers website for facts and figures and it reckons the tfsi and the tdi 140 are the same weight as on supplier sold 2 different spring sets for the a3 2wd 8p one was for below 1020kg and the other was for above.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    FWD and Quattro use different springs though. If you've got the same drivetrain as your mate then it's all good, if not then his springs will be no good for you.
    Mar 2013
    21
    Cheers for your help, were both 2wd so all is good. Thanks again.
  1. S3 springs to 19.Tdi
    By pinterovski in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th October 2011, 16:10
  2. S3 SPRINGS ON A TDI SLINE - Would they fit?
    By andi1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2011, 20:43
  3. S-Line Springs on Sport (TDi)?
    By LSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2011, 11:11
  4. I'm about to change the springs on my TDi - any advice?
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2006, 09:30
  5. Can anyone reccomend a cheap set of lowering springs for a Tdi on 17's
    Last Post: 1st August 2005, 15:31
