I've wanted to remove the car phone from my car since I've got it but thought it would be to hard to do. If you try to use it, it also mutes music playing from the radio. I recently took out the glove box to replace the blower motor. Whilst I was doing that I saw the box for the car phone for the first time and I thought this is my chance to hopefully get rid of it.
The only thing is that they seem have installed it quite well. They have used an adapter but with all the wires that are about I'm not sure if some of the wires have to be taken out of the adapter and placed back into the original RNSE plug/socket? Also They seem to have wired the blue ignition wire to the back of the fuses located on the drivers side, how can I get to them? Can the bit where you plug in the vcds be removed? I took loads of pics hoping that somebody could advise me further.
This is a pic of the lovely phone..... Not
And the main box where the sim cards goes is below, this was located behind the glove box, tucked in behind the blower motor.
Here's a pdf guide for it. Section 11 tells you what the wires are for from the unit. http://nds1.nokia.com/phones/files/guides/Nokia_810_UG_en.pdf
Then there is the blue wire that I believe runs to the drivers side fuse box.
