Log if it helps..!!!
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Monday,27,May,2013,17:10:45:41744
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P85A055166 Mileage: 195170km/121273miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 7364
Revision: 12345678 Serial number: AUX7Z0D8FNF0AW
Coding: 0000072
Shop #: WSC 01286 386 08256
VCID: 6CDDF45B4F28E778ED4
1 Fault Found:
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 122.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000100
Temperature: 27.0°C
Temperature: 23.4°C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A71020375FC89C82F8
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 094722 Serial number: 8P0820043D
Shop #: WSC 06314 000 00000
VCID: 2D5B395FB4B22E70BAA
2 Faults Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 185892 km
Time Indication: 0
Date: 2012.10.06
Time: 12:20:08
Freeze Frame:
ON
01317 - Control Module in Instrument Cluster (J285)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 192047 km
Time Indication: 0
Date: 2013.03.09
Time: 17:14:29
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001046640
Coding: A9084A20B014100F00161600160000001901FE0D00
Shop #: WSC 00000 000 00000
VCID: 3D7B091F64D2BEF00AA
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00063760
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 2620
Revision: 91H10262 Serial number: 00362000E5PC
Coding: 0034622
VCID: 42817AE31D2CC108778
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H11 0020
Coding: 0002012
VCID: FBFF4707BA46F0C0F4E
Part No: XXXXXXXXXXX
Component: Lenkradmodul H02 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
Component: KOMBIINSTR. VDO H71 0210
Revision: D03 Serial number: 2248DD03005752
Coding: 0004408
Shop #: WSC 25003 124 54969
VCID: 448D7CFB0738CF38454
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 250010490103DC
Coding: 3D3F0B4A072103
VCID: 2855C84B9B500B5849C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D03 Serial number: AUX7Z0D8FNF0AW
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
Component: RNS-E HIGH EU H74 0650
Revision: 02S Serial number: AUZBZ7H0916345
Coding: 0205115
Shop #: WSC 28231 142 62641
VCID: 3875180B4BF09BD8D9C
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.14 1301
VCID: 3065202BA380439891C
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H03 0050
Coding: 188000003F008D0D481FC61000
Shop #: WSC 00183 210 58462
VCID: 3C7D041B7FC8B7F83D4
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH02 0160
Revision: 00001 Serial number: 10000001168436
VCID: F1E3652FE80A8A905E2
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Coding: 0000048
VCID: 3E790E1369D4A5E8130
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205115
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG H10 0010
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0000144
VCID: 3F8773176EDEACE0186
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
