Volks AutosMonster Motorsport
Page 2 of 2 FirstFirst 12
Results 41 to 69 of 69
Like Tree22Likes
Thread: Michelin or conti
  1. #41
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,426
    Quote Originally Posted by I oOEddOo I View Post
    I will need to get ringing tomorrow and try my luck otherwise I have to settle in with Conti 5 :S
    Good luck.
    Either way,you should be happy,and if it's the stock Bridgestone's you're replacing,ANY of the tyres mentioned are better.
  3. #42
    Mar 2010
    Somewhere
    324
    Quote Originally Posted by S3Alex View Post
    Good luck.
    by the way i am replacing conti 2
    seems continental is much cheaper than Michelin thought those two are battling all the time ... if i do end up with conti 5 hope they wont let me down
    S3Alex likes this.
  4. #43
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,426
    They won't I'm sure.
    I've not used them,but the reviews have all been good.
  5. #44
    Mar 2010
    Somewhere
    324
    Cheers for all your help and advice S3Alex and everyone
    S3Alex likes this.
  6. #45
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,426
    A pleasure!
    Everyone here has been so helpful in showing me how to part with my money,that it's only fair I help others to do the same!
  7. #46
    Jul 2012
    Cheshire/N Staffs
    1,401
    If you opt for a 88Y
    instead of the Audi fitted and recommended 92Y XL
    if you have a crash, won't the insurance have an issue with a tyre that isn't specified by the manufacturer?
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
  8. #47
    MBK
    MBK's Avatar
    May 2012
    Neath
    1,156
    Quote Originally Posted by veeeight View Post
    2nd paragraph here might help for an easy explanation:
    What does the writing on my tyres mean?
    Or here is the full law if you prefer:
    The Motor Vehicles (Approval) Regulations 2001
  9. #48
    Jul 2012
    Cheshire/N Staffs
    1,401
    So whilst you know the static load of the front end of an Audi S3
    Do you know what the Dynamic load of the front end of an Audi S3, 3 passengers and driver, luggage, under full emergency braking from 155mph, on a dry road ambient temperature of 40 degC?
    Might the insurance company have a case for not paying out if you have fitted 88Y tyres that are not XL rated?
  10. #49
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,426
    Good point.
    The other side is that both sets of tyres are Y-rated,and the load difference amounts to 70kgs.
    I'd need someone with a better knowledge of physics and tyre load margins to work it out for me,but in your illustration of course,you'd be prosecuted for the speed alone!
  11. #50
    Jul 2012
    Cheshire/N Staffs
    1,401
    Indeed
    I'm just extremely wary of insurance companies finding the slightest excuse not to pay out.
    We already know that they will refuse a payout on non "N" rated tyres for Porsches
    With XL rated tyre, it's more than just the load in kilograms.
    An XL tyre fitment as standard makes sense on a S3. With a low profile tyre, there isn't much of a sidewall. An XL tyre has reinforced sidewalls to cope with the additional lateral cornering dynamics, and enables the tyre to run at a higher inflation pressure to cope.
    A non XL 88Y tyre, whilst having a lower static loading, hasn't got reinforced sidewalls!
    Interestingly, a XL tyre inflated to the same pressure as a non XL tyre has a lower load capacity. A XL tyre must be inflated to, and run at a higher pressure than a non XL tyre to achieve the same load capacity. This explains why recent 8P's run at 42psi on the front.
    At the end of the day, if a car/tyre hasn't been homologated by the manufacturer, the insurance company may seek to exploit this
  12. #51
    964kevin's Avatar
    99
    Indeed
    Thats not true with regards to Porsche, I can vouch for that having more than one friend with them, and no-where does it state on any policy I have had that N rated tyres must be fitted.
    Regards
    K
  13. #52
    Jul 2012
    Cheshire/N Staffs
    1,401
    It does state on most policies that the car must have tyres fitted as recommended by the manufacturer.
    There certainly enough noise on the Porsche Forums that indicate this is a problem area with compliance.
    Has your more than one friend with Porsches actually had a claim paid out with non N rated tyres?
    *Nevertheless, N ratings are more to do with compound, XL ratings are to do with load dynamics and construction!
  14. #53
    964kevin's Avatar
    99
    I wont hijack anymore, but suffice to say.
    Claims, yes paid ok, no mention on the policies I've had for the last 12 years, and the N rating cannot be applicable for all Porshces, as they are only tested on current models, so if you have an old one, then the charateristics are not always applicable.
    N types are also construction and compound related, at least that is what the Michellin engineer infomred us on a talk a couple of years ago regarding tyre manufacture and testing..
    Regards
    K
  15. #54
    Jul 2012
    Cheshire/N Staffs
    1,401
    Policy wording (I'm sure most policies state this):
    . Modifications to your car
    You must tell us what modifications you intend to make and obtain our agreement prior to making them. Modifications are changes to your car’s standard specification, including optional extras. These include, but are not restricted to, changes to the appearance and/or the performance of your car (including wheels, suspension, bodywork and engine).
    Failure to provide correct information or inform us of any changes could adversely affect your policy, including invalidating your policy or claims being rejected or not fully paid.
    At the end of the day, it's your risk, your car, your insurance, your life! But I still fail to see why you would use potentially weaker non XL tyres on a high performance car (away from Standard Specification).
  16. #55
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    I may need new tyres and like Conti as a brand. Have done a quick search and was wondering if anyone knows the difference between these two and why the wet weather rating differs?
    Could be glitch on website as just did a quick search.
    S3 Sportback
  17. #56
    Jul 2012
    Cheshire/N Staffs
    1,401
    At first glance it looks like the left tyre is a manufacturer specific tyre MO = Mercedes Original
    These links will help:
    Speak fluent ‘tyre’ in one minute | Tyre Basics | | Learn and Share | MICHELIN
    Mercedes 'MO' Rated Tyres
  18. #57
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Thanks. I'll go for non merc ones when I'm ready - I prefer being able to drove in snow and the non merc one has a higher wet weather rating.
    S3 Sportback
  19. #58
    Mar 2010
    Somewhere
    324
    Conti 5 it is folks
  20. #59
    rezulteo's Avatar
    Sep 2011
    224
    Follow rezulteo On Twitter Add rezulteo on Facebook
    Conti 5 it is folks
    Let us know what you think! Tyres are always tricky...
    All tyres for Audi and tyre news, advice, tests and comparisons on http://www.rezulteo-tyres.co.uk
    Follow us on Twitter !
    Like our Facebook page !
  21. #60
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    They make an Audi specific Conti 5 which has different ratings too. Let us know which ones you go for.
    S3 Sportback
  22. #61
    Mar 2010
    Somewhere
    324
    Quote Originally Posted by Wicked666 View Post
    I went for the audi ones
  23. #62
    Jan 2013
    159
    I too need 4 Tyres for my 2007 S3. Going for PS3 at a cost of £111 each including postage. Getting them fitted at WIM along with full alignment
    225/40/18 by the way
  24. #63
    Mar 2010
    Somewhere
    324
    Quote Originally Posted by mmalh0151 View Post
    Just wondering which site you went on for that price??
  25. #64
    Jan 2013
    159
    Hi its a site for forum members so you will have to ask for a login but heres the link for them tyres...https://www.tyrefactors.com/tyresear...&marque=&other
  26. #65
    Jan 2013
    159
    Contis are here https://www.tyrefactors.com/tyresear...marque=&other=
    Price difference of £5 or so
  27. #66
    Mar 2010
    Somewhere
    324
    yes all the site i went on prices for ps3 is like £120+
  28. #67
    Jan 2013
    159
    I gave ordered from them before with no problems for my lexus. Going to order 4x PS3 this week
  29. #68
    Mar 2010
    Somewhere
    324
    Good Good
  30. #69
    964kevin's Avatar
    99
    I thought it might be of interest to anyone looking for PS3's that in some Michellin garages are offering £50 cash back before the end of the month, mine are £127.50 fitted at a local garage, with the £50 back, thats £460 the set...
    K.
  1. Replies: 11
    Last Post: 18th February 2013, 19:16
  2. Tyres??? Michelin PS2 or Conti-Sport-Contact 3
    By Maz in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2011, 20:52
  3. Michelin Pilot 2s to Goodyear Eagle F1GSD3s
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th June 2005, 11:14
  4. Michelin Tyre Warning
    By hop2407 in forum General Chat
    Last Post: 23rd June 2005, 21:27
  5. Michelin Pilot Primacy.....good bye and farewell!
    By evotista in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2005, 00:38
