AH FabricationsEM Tuning
    Feb 2011
    Falkirk
    296
    Dynamic Headlight Range Control
    Hit a massive pothole last night whilst going round a corner and now I keep getting the 'Dynamic Headlight Range Control' warning light coming up on the dash.
    It only came on this morning after driving for about 20 minutes so think it might just be a loose connection somewhere.
    I think I can remember when I had the TT that the level sensor was on the back wishbone and it was just the plastic arm that snapped then. Can anyone point out where it is on the A3?
    I had a quick look last night but it was hammering down with rain so gave up relatively quickly
    Dazz
    26,720
    Front/rear left are where the sensors are fitted, have to get down there with torch & see if an arms bent or broken.
    Feb 2011
    Falkirk
    296
    Thanks, Ill try have a look tonight again, took it for a spin at lunch and it only came on after about half an hour drive so don't think its completely broken
    Feb 2011
    Falkirk
    296
    Had it in my mates garage to get checked. The rear spring had snapped (must have been when I hit the pothole) and also checked the sensor but cant see anything wrong with it. Also disconnected it and reconnected to see if this would clear the fault but it's still there.
    Any ideas?
    Don't know if it will still be covered under Audi waranty or not, as I had to change the springs (to Eibach -50/40mm) wonder if this may void the warranty
    26,720
    Needs to be stuck on vcds & the sensor inspected properly, may need a calibration, but ideally need to see if vcds sees it connected or not.
    Brotek aren't far from you.
  1. Yellow warning light- Dynamic Headlight range control faulty
    By CO11K9 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th November 2012, 11:20
  2. Replies: 1
    Last Post: 31st May 2010, 10:58
  3. "Dynamic Headlight Range Control Faulty" warning on DIS
    By gcs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2010, 15:48
  4. headlight range control
    By kanievsky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2007, 15:57
  5. Dynamic headlight range control faulty
    By gav in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th August 2007, 07:53
