Badger5Volks Autos
Results 1 to 13 of 13
    Mar 2011
    15
    Cruise control coding, derby?
    Could anybody point me in the right direction? For somebody in the midland area to code in my cruise control? I have fitted it but not coded it. I think I'm ok for the extra wire too, see pic?ImageUploadedByTapatalk1369640423.874539.jpg
    I'm willing to travel a bit if needs be, I'm a bit lost when it comes to the coding stuff!!!
    Oct 2012
    Warrington, North West
    986
    If your still stuck ill be travelling to kenilworth for the rest of this week, might be a bit far to travel though?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,453
    TDI140's Avatar
    May 2011
    1,350
    European car specialist burton on trent or one stop performance burton on trent or cctuning (chris) burton on trent they all have VCDS they can code it aslong as you tell them what to do and what needs changing etc etc
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Mar 2011
    15
    Thanks for your replies guys, I should've mentioned that I have a problem with it also! It has thrown up some codes and wiped out my power steering totally! It has thrown up codes for the steering angle sensor and the steering lock along with triggered the ESP light and also the steering wheel light! Is this common? I did a search but I'm really not to great with electronics and get lost in details!
    Oct 2012
    986
    Have you had the battery off? If do then take it for a drive and they should clear
    27,094
    I'll be driving about this week sometime, maybe up in Stoke area & I could sort your issue out.
    Mar 2011
    15
    Yeah mate, I had the battery off. But it's been to London and back since too. I tried to calibrate the steering angle sensor and it was doing nothing. Do you have much knowledge about the slip ring? I'm thinking maybe I disturbed it and that needs coding in or something? Do you think this could be the case?
    Mar 2011
    15
    I'm going to stoke myself at some stage but yeah I could drive there no problem, any help would be brilliant mate!
    Oct 2012
    986
    NHN is the god of this stuff, he'll sort you out, and have you got my pm Nigel?
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    I'm not too far down in Nuneaton and can do it. PM me if you want to sort something.
    Mar 2012
    369
    There's an outfit in Long Eaton that advertises on eBay - they supply the OEM cruise and fit 'em so maybe they could sort you out.
    27,094
    Quote Originally Posted by Swinny View Post
    Ping me a PM & I'll check which day I'm there for client.
  1. Cruise control coding for 3.0TDI engine module
    By be@st in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th March 2013, 18:02
  2. retrofit cruise control coding and activation issue
    By deian3387 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2012, 18:58
  3. a3 8p cruise control instructions & vagcom coding?
    By fizz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2012, 14:17
  4. Cruise Control on 09 B7 - Binary Long Coding ?
    By Masterm8fo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th June 2011, 14:12
  5. Cruise control coding A3 8P
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th February 2008, 17:13
