Badger5Monster Motorsport
Results 1 to 7 of 7
    May 2013
    24
    Rear cylinder grease!
    Hi again, done all 4 discs and pads on my 2010 A3 diesel today and before pushing in front brake pad adjuster ( to refit new pads ) l. Noticed a fine smear of what looked like to me grease, lam sure it wasn't brake fluid( is it possible it could be grease? ) thanks
    Apr 2013
    Kettering, Northamptonshire
    172
    Where abouts, could be grease from the slider pins in the carrier, or grease from ball joints or cv grease from cv joints?
    May 2013
    24
    Hi, it was when winding in the front brake piston/cylinder l noticed it under the rubber seal around the piston
    Apr 2013
    172
    Oh I see, probably there from factory then to stop the piston seizing/rusting, as long as its definitely not brake fluid from pushing the piston in to fast and flipping internal seals and not grease from elsewhere I wouldn't worry about it.
    May 2013
    24
    It was there before l started winding it in, iam sure it was grease, quite dark in colour
    Apr 2013
    172
    it shouldn't come out though so id check the dust cover isn't split, if it is without seeing if there is a repair kit id get some silicone to seal the hole or water will get in, seize the piston and the caliper wont perform. Sometimes if you put oil behind the dust cover on a seized piston they can free off but could be new caliper.
    May 2013
    24
    The dust cover looked fine, it was just a little between the piston seal and rubber, lam sure its ok and lam worrying about nothing
  1. Stolen Rear Badge
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2013, 05:46
  2. Rear Bumper!
    By Moresauce in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2006, 21:58
  3. Rear Bumper Removal
    By Jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2003, 13:10
  4. New rear badge - help required
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 21:42
  5. Rear side panel removal ?
    By vwchico in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2003, 07:43
