Chris NottAH Fabrications
Like Tree1Likes
  • 1 Post By NHN
Thread: Suspension help please.
    Jan 2013
    South West
    42
    Hey everyone.
    So i had my AP coil overs and Eibach ARB's fitted a couple of week ago, first couple of days were glorious far better handling and turn in. However i started to hear a slight rattle/groan/creak on what sounds like the offside going over bumps. Since then this has been getting progressively worse. I have now changed the top mount, rear wishbone bush and ball joint thinking it was the cause to no avail.
    Now i seem to remember hearing somewhere that the standard drop links might need changing as they are too short for the new ARB.... is there any truth to this?
    I have taken it back to the person that fitted the shocks and ARB's and he scratched his head after a test drive not having a clue what it could be.
    Any other suggestions would be welcome before i bite the bullet and take it to the stealers.
    27,043
    Front arb could knock on the upright, I had this issue on passenger side, I actually got a grinder & smoothed of the angular edge of that upright & this helped a bit, now it may not be your issue, but it was with Eibach ARB's I had issues with.
    I would remove the connecting links temp, tie arb up safely so not interfering with anything else & see if the issue goes.
    tommo5600 likes this.
    Jan 2013
    South West
    42
    thanks mate
  1. Need suspension help please!!!
    By Coletti in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2012, 19:27
  2. Audi a3 suspension HELP?? please
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2010, 21:50
  3. Suspension help please!want to lower
    By jarvis**turbo** in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th September 2007, 19:36
  4. New Suspension kit please help
    By Herby1 in forum General Technical / How To
    Last Post: 19th July 2007, 15:34
  5. Suspension help please
    By domcj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th October 2005, 13:40
