Results 1 to 12 of 12
    Wilky5's Avatar
    Feb 2013
    32
    Tidied up the back of my A3
    Had the A3 2 months now, I'm really enjoying it. Todays been my first opportunity to spend some time on it. Decided to spruce up the back end in prep for getting some my11 lights. On one hand Im happy with the result, on the other hand Im gutted.
    The exhaust tips have come up a treat, they were barely visable before. I dont like badges, so VERY carefully removed them with dental floss, didnt want to risk scratches. Soon became evident that they'd been taken off before and put on with some heavy duty glue. Its raised up from the paintwork and looks awful. Tried AG tar and glue - didnt work. Tried T cut (gently) - didnt work. I debadge my last car, quick job, just peeled of the remaining sticky stuff, a quick polish and looked great. Im now left with the decision to either put some back on, or rub it down and have the boot resprayed =-(
    Sim_88's Avatar
    Jun 2012
    London
    55
    I had a similar issue when I debadged my boot.. A decent mobile bodywork specialist should be able to get rid of the marks relatively cheaply.. I didn't even get charged as I was getting my alloys refurbished at the same time.
    2.0 TDi S-Line | BOSE | iPod | Full Leather | Electric Mirrors | Armrest | Rear Tints | Diamond Vision | MY11's
    Dec 2011
    226
    Just get it sprayed mate as you wanted the badges off so there's no point putting them back on
    Wilky5's Avatar
    Feb 2013
    32
    Quote Originally Posted by Sim_88 View Post
    A friend of my Dad's owns an auto cosmetic company and body shop. Going to go see him Tuesday, see if he can fit me in whilst I'm off work this week
    Dec 2012
    205
    what did you use on the exhaust tips?
    JPK
    May 2012
    278
    Try a heat gun
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    TDI140's Avatar
    May 2011
    1,293
    My exhaust are thick charcoal black due to over fueling also throws out alot of smoke, map needs adjusting, but your car looks clean pal
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    405
    In regards to your Sticker glue residue, i would recomend using some UPVC cleaner to remove the badge glue - then dress the area with a abrasive polish. When i initialy removed my badges i had a little glue left over and this removed it. However 8-9month later you could see where the badges had being, the paint was cleaner under where the badge had being, this was cured with a full detail with a DA yesturday by a friend.
    Hope you get this sorted, let us know what happens
    Black Audi A3 8P 2.0TDi
    V-Maxx Coil overs | S3 Rear Spoiler | De Wiperd | TTRS Alloys | S3 Rear Bumper | S3 Side Skirts | Votex Front Spoiler | LED Ring in Fogs | LED Interior Lights | LED Number plate lights | Custom Foot well lights | DPF Removed | Green Cotton P/F | JBS Phase 2 | Pressed Plates | LED Side lights | Custom Rear Light tint | Complete Matt Black Plasti Dip | Honey Comb Front Grill | Silvertec Indicators | BOSE | Sunroof | Forge Short Shift
    Oct 2012
    Warrington, North West
    959
    I had similar issue, I used hot water then pealed most of the glue off by hand, then used AG tar remover on the residue. Then polished and waxed the boot lid
    Wilky5's Avatar
    Feb 2013
    32
    Thanks all. My exhaust tips were disgusting, completely blackened. I just used a tube of T cut scratch remover and a lot of elbow grease, they came up well eventually. No way are they being allowed to get as bad as they were.
    With regards to the glue, I've tried AG tar and glue but it didn't do anything. I've removed all of the "normal" adhesive that they're stuck on with. Someone has clearly removed them in the past and stuck them back on again with something else
    Oct 2012
    959
    What did you use on your tips?
    Wilky5's Avatar
    Feb 2013
    32
    Just to cut and elbow grease. I've just bought some chrome polish to bring them up even better
  1. Replies: 8
    Last Post: 17th November 2005, 13:55
  2. Beeping from somewhere in the back.
    By s3bow in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2005, 10:45
  3. Sorted out the back and put some mirror-housings on...
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2005, 18:50
  4. Had a spin on the back of a R1 this afternoon!!
    By Soupie69uk in forum General Chat
    Last Post: 14th June 2005, 14:18
