AH FabricationsEM Tuning
Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By voorhees
  • 1 Post By nil538
  • 1 Post By H17YD L
Thread: Got a Slight Problem .................................................. ..............
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Unhappy Got a Slight Problem .................................................. ..............
    I was planing on fitting a OEM Shark GPS/Aireal Antennae this Bank Holiday Weekend .
    When I realized that I didn't have the hexagon nut in the ETKA picture you see below.
    I've asked a couple of people I know if they have anything something similar that would fit round these fine grooves as it looks like these twirl grooves are very close together.
    Picture below :
    Can anybody advise where I can get a similar nut to fit ? Or maybe a alternative way to secure this shark aerial down ?
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    882
    Stupid question but why not purchase the nut from the dealer if that's what you need to fit?
    Failing that, any nut & bolt specialist should be able to sort you out. Bapp ltd are a good shout.
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Quote Originally Posted by ShaunS3 View Post
    Bank Holiday TPS is closed. Of only got this weekend as time is a bit tight right about now.
    Are Bapp ltd open on Sundays ?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Cable tie it until TPS open
    Digzz likes this.
    Dec 2011
    235
    Take it to b&q and see if there is something with the same Thred in the plumbing bits maybe ?
    Digzz likes this.
    Dec 2012
    241
    I can't tell in the picture but it looks like M20. Try B&Q for a 20mm plastic stuffing gland what you would normally use for cable and see if the locknut fits ur thread. Or u could try a 20mm SWA gland as they are the same size locknut and it would be metal, take it with u and have a try
    This is the stuffing gland:
    Digzz likes this.
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    347
    347's Avatar
    Sep 2006
    253
    Might be worth trying Maplins or a electrical component type shop ?
    good luck
    2010 2.0 Tfsi BE ibis white DSG , now sharked
  1. Have i got more serious problems? Smoke - video inside.
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2010, 20:17
  2. Just got an S3 and got a few problems
    By dnLcal in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 18:22
  3. New Member, Slight problem
    By TopT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2007, 11:47
  4. Slight problem
    By S4_SAT in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th August 2007, 08:03
  5. A slight problem!
    By k17rpo in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2006, 19:28
