Volks AutosMonster Motorsport
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By voorhees
Thread: So ... this just happened
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    839
    Was jacking up the car for some weekend caliper painting. The car shifted on the jack, the wood block I was using to protect the car tilted and dented in the round bit before the lip. Pics:
    This looks like it has sent the door out of alignment, as the door/arch area isn't flush along the bottom and the gap between the door and the adjacent panel is larger than the other side of the car.
    This has made me proper angry. How can I go about fixing it?
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,783
    Bad news.
    Someone here will know someone who can.
    Good luck with the repair.
    wuta3's Avatar
    Jul 2012
    839
    Quote Originally Posted by S3Alex View Post
    Bad news.
    Cheers fella, hopefully get it sorted without blowing my mods fund.
    Lewis583's Avatar
    Mar 2010
    830
    That's the sill you have dented.
    I don't think you can get access to the inside of the sill via the front wheel arch, but I'm not 100% on that.
    Try removing the door step trim to see if there are any holes big enough to get a drift through and knock it back out.
    The only other way I can think of without having to cut it open, involves a welder/a grinder with wire wheel/ some bolts and a slide hammer with hook attachment.
    Basically clean of the dented area with the grinder(with wire wheel fitted)
    Spot weld some bolts to the dented area.
    Screw a nut onto a bolt, then hook the slide hammer round the nut
    Using the slide hammer, pull the dent back down.
    Best way is to give each bolt a go and slowly pull the dent out. It will need painting/undersealing afterwards
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Lewis583's Avatar
    Mar 2010
    830
    Actually I have just found a variation on the weld pulling method that involves gluing instead of welding
    LINK
    Full VCDS
    TDI140's Avatar
    May 2011
    1,293
    You have jacked up on the side skirt u donut damaged the body so u prob need new skirt
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    TDI140's Avatar
    May 2011
    1,293
    Does that not come off ? As a whole piece ? Could be an excuse to get vortex skirts or s3 skirts ???
    wuta3's Avatar
    Jul 2012
    839
    Quote Originally Posted by TDI140 View Post
    Ure a donut! I was jacking on the weld using the "wood with a groove" method and the car shifted. I know better than to jack it up on the soft area, read the first post next time :P
    wuta3's Avatar
    Jul 2012
    839
    Oy donut, it isn't the skirt that is dented. its a non removable part, the metal iirc is part of the chassis.
    wuta3's Avatar
    Jul 2012
    839
    Quote Originally Posted by Lewis583 View Post
    LINK
    Yea was hoping to avoid pulling. The metal seems pretty thin and fragile there, don't want to split it. I'm sure access to the inside to push it out is possible.
    Might nip to a bodyshop after the weekend. Turns out it isn't as bad as I thought, the door alignment is fine, just the sill area is a bit mis-shapen.
    wuta3's Avatar
    Jul 2012
    839
    S3 skirts I think wrap the area that has dented. Not a bad shout though if I can't get it flush again.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,610
    Get a hockey puck for next time
    wuta3's Avatar
    Jul 2012
    839
    Quote Originally Posted by voorhees View Post
    Was using wood with a cut in it for the lip ... yes, hockey puck next time.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,610
    Quote Originally Posted by wuta3 View Post
    **cough** cheapskate **cough**
    Eftwyrd's Avatar
    May 2012
    39
    If you do find an easy fix let me know, mine is that same. Previous owner must have had to jack the car at the road side using emergency jack. When I looked at it it looks like if the ground isn't level the threaded part of the jack can make contact with the sill.
  1. WARNING This could happen to you
    By WHITEY_1 in forum Jokes, Games & Humour
    Last Post: 4th May 2010, 14:15
  2. Has this ever happened to you??
    By DJ-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2009, 15:34
  3. This could happen to you!
    By jojo in forum General Chat
    Last Post: 16th January 2009, 17:44
  4. Is this just me?
    By Audi5000 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2007, 16:17
  5. Is this just me....
    By SyA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2005, 19:46
