Sky InsuranceChris Nott
Results 1 to 7 of 7
Thread: air con issue
    Mar 2012
    Deep in the staffordshire moorlands.
    123
    air con issue
    Recently had a double din conversion done and now my air con is acting up. Air only comes out of the vents when the econ button is lit up. The fan still sounds like its working when the econ isn't on bit no air comes out the vents. The air con pipes under the bonnet are still cold if the makes any difference. Can anyone help as I'd like to sort it quick if it's an easy fix now the weather's warming up. Thanks for any help in advance.
    26,754
    Did you reuse the same climate unit or fit another?
    Mar 2012
    123
    fitted another
    26,754
    What year car is yours?
    What's the manufacture date of that unit & part number, is it the facelift with chrome dials?
    Mar 2012
    123
    54 plate and no its just the double din version of the one I had not the facelift one with chrome dials.
    26,754
    Well you need to check the part number & date, there are black versions that were fitted to post mid 07 onwards cars that used the facelift heater systems which aren't compatible with earlier cars.
    Mar 2012
    123
    That is probably the case. Thank you for the help.
    I have the new facelift buttons fitted, how hard will it be to quickly pull those off so I can get the air con unit out to swap the faces and put my old one back in?
  1. A6 C6 Air Con issues
    By JimC64 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 12th July 2013, 13:32
  2. S4 air con issue
    By marctwo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2011, 10:55
  3. 1.9tdi 130 Air con Issues!
    By ashatplay in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th June 2011, 16:24
  4. Air Con Issues ***please help***
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2010, 08:48
  5. Air con issue
    By imported_paragon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2005, 15:02
Tags for this Thread
