Volks AutosSky Insurance
    May 2013
    6
    Front wheel / suspension question (intro aswell)
    Hi Guys
    Rather new to this forums but not new to the scene!
    So i bought an 06 A3 2.0T FSI DSG with 100,000km on the clock, Lava grey in colour and completely stock. will definitely post up some pics soon. Im also from Australia (Melbourne)
    Now even with the stock 147kw, I still cant seem to get traction on cornering, launches etc on standard 17's.
    My first question is on standard ride height or sport suspension what are the widest wheels i can run in the front without rubbing?
    I have seen alot of people run 8.5" with et40 but can we go any wider? I have searched and cant really find a answer, also looked thru the 'rimzzzz' thread and there isn't many pictures with specs attached to them
    Thanks in advanced
    George
    JPK
    May 2012
    278
    Make sure you have a decent tyre first off.
    Im running 225s, Whiteline ALK + front bushings and 034 Motorsport engine/trans/dogbone insert. I don't really have any traction issues in the dry and I have a remap + intake.
    WALK made the biggest difference to traction. Uprated shocks/springs will give better traction when cornering in addition to the above too.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    JPK
    May 2012
    278
    To answer your initial question. Without getting ridiculous poke and or rubbing on the inner arch, 225s are about the limit on a lowered car. At standard ride height I imagine 235s will be fine but won't look the best.
    RS3s go wider but they have flared front arches so they can drop the offset without the wheels poking past the guards.
    May 2013
    6
    I'll be running conti sport 3's
    I'm also looking for a flush look on the front so a 8.5" with et 40 and a 225 or 235 tyre will be fine? E standard tyres are 225 right, so what benefit would I get by running a wider wheel wight e same size tyre?
    How do you find the walk and bushings over stock? What size wheels and tyres are running? Also any traction issue off the line?
    JPK
    May 2012
    278
    No drawbacks with WALK in my opinion. I have a bit of stretch and slight poke with 19x8.5 43et and 225/35/19 tyres.
    Here is my build thread that has more info/reviews, need to get around to posting it in the project room on this site.
    My A3 Sportback Progress Thread/Diary
    RE traction. I get better traction off the line now with another 50bhp or so than I did stock.
    May 2013
    6
    Had a read through your build thread, pretty impressive and beutiful looking car i must say,
    Du you order the whiteline productsa direct from there website? Considering your in NZ and im Aus im interested to see where you find your parts.
    I have also decided on 18x8.5 et43 front and 18x9/9.5 et40 rear. Will be looking to ordering the WALK aswell,
  1. front S4 Discs and carriers on an A4 Wheel size question
    By Molnboman in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th May 2013, 19:12
  2. Front suspension question?
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2010, 16:36
  3. Front s3 suspension question asap please!
    Last Post: 3rd August 2010, 13:03
  4. Lack of traction at front wheels
    By cyberdude in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2004, 23:40
  5. Suspension question s3
    By tvr1 in forum Handling
    Last Post: 17th July 2003, 23:49
