Chris NottMonster Motorsport
    Mar 2012
    Flywheel and clutch
    Hi all. I've just been quoted £1177 for a dual mass flywheel and clutch replacement from an Indie. Seems horrendously expensive to me. Its a 2008 2.0 TDi 170. Does anybody know somewhere that may be able to do it cheaper? I'm not bothered where if I can save money. Thanks for any help.
    Stol1975's Avatar
    Sep 2012
    227
    I had the same question a few weeks ago. I got Audi down to £1050 so your independent seems too expensive. I had it done a back street garage for £745 in the end and all seems sweet at the moment. I got a 2 year warranty with it too.
    Feb 2013
    262
    I would expect that even the cheapest wont do it for less than 700 fitted
    very roughly you can get Dmf for 300 and a clutch kit for 150 and a release bearing for 35
    I've just payed 240 labour to fit and tht was based on four hours bearing in mind most will quote longer than this (6-8 hours is not unheard of)
    I payed about 1150 to have a loba clutch fitted to an audi s3
    Audi S3 : revo stage 2+
  1. How many hours to change flywheel and clutch? 1.6tdi
    By Mikemc in forum General Automotive Chat
    Last Post: 3rd April 2013, 19:26
  2. Problem after replacing LUK flywheel and clutch?
    By Jamie Triner in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2012, 20:50
  3. Sachs flywheel and clutch kit from techniclutch
    By shabba168 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2011, 11:59
  4. Changing flywheel and clutch luk or sachs can either fit? Quick answer please
    By danonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2011, 22:22
  5. 1.9 tdi 130 dual mass flywheel and clutch kit - how much ????
    By blucoop in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st December 2010, 17:44
