Right car was in at audi today with suspect boost leak causing this noise outcome was that there was a split hose to turbo which was replaced and also a seal was replaced on inter cooler hose after I mentioned a oil leak.
car does run better etc but there is still this noise which I'm unsure of when you accelerate and let off there is a dump of air (this is different noise now and only way I can describe is a mouse like sneeze) this only does it up to about third
now to me sounds like its dumping air but as far as I'm aware you don't have dump valves on diesels
its a 2.0 tdi
its a 2.0 tdi
