Monster MotorsportVolks Autos
Results 1 to 10 of 10
    Crunching The Gears
    Apr 2012
    Invergordon Scotland
    402
    CMC Air intake:)
    After looking around at air intakes and not wanting to spent a fortune I decided to make my own.
    Got everything I need of eBay. Total cost was around ÂŁ60.
    It makes a good sound once the car hit 3kRPM.
    Started off with the cold air feed, which was a mod in itself.
    Just before going in.
    In its final place.
    From another angle.
    Looks ok doesn't it?
    Any suggestion to improve on, other than a heat sheild.
    Thanks Corey
    Mods so far...
    LED Interior Lights, Front splitter, 10mm Front Spacers, Cruise Control.
    Puddle/ Footwell Lights, LED spot, number plate and side lights.
    75% Window Tints, MY11 Lights, Black Optics Grill.
    MFSW, Leather trimmed Grab Handles.
    Custom CAI, CH/LH Lights
    JL Audio, DAB radio
    Vinyl wrap wing mirrors
    Mods planned...
    JETEX Cat Back System
    Remap, Rear Spacers, RNS-E, Bluetooth,
    ARBs, Alcantara roof
    TDI140's Avatar
    May 2011
    1,293
    Stands out would be much better with heat shield, also does the bonnet not hit it when its down as it seem a bit high up pal ?
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    Crunching The Gears
    Apr 2012
    402
    Haha thanks yeah just a little bit. But better being bright.
    What would be best for a heat sheild? Aluminium sheets surrounding it on the sides and top or...?
    Its a close fit to the bonnet but no rubbing or anything so it's all good
    Mods so far...
    JL Audio, DAB radio
    Mods planned...
    TDI140's Avatar
    May 2011
    1,293
    Yh some reflective metal to keep engine heat away from the actual cone filter, bet it sounds awesome, yh looks nice in red stands out i have red hoses under my hood too i love them people get amazed if i pop the hood as its a TDI
    Apr 2013
    Kettering, Northamptonshire
    171
    Watch out for puddles, if that air feed sucks in water it will bend a con rod!
    Jul 2011
    216
    Aqua lock comes too mind with that cold air feed but otha wise looks good for the money
    TDI140's Avatar
    May 2011
    1,293
    How does that happen ?? Shoots cold water right into the engine block ?
    Feb 2013
    262
    that won't happen, there is no way that there will be so much suction at the cone that it will pull water up the cold air feed dispite the fact it's not even connected! I've had this happen to me before an it was on a bmc cda with sealed intake and cold air feed mounted to the bottom of the bumper, my cylinders were full of water and I ended up with a new engine
    Audi S3 : revo stage 2+
    TDI140's Avatar
    May 2011
    1,293
    What about intakes on tdi's ? The intake goes onto the turbo will that have any issues as im looking at getting a boxed air intake
    Crunching The Gears
    Apr 2012
    402
    Thanks for the comments guys.
    Yeah don't think I'll aqua lock my engine tend to stay clear or puddles and water spray.
    Should have an update in a few week with the air box .
    Mods so far...
    JL Audio, DAB radio
    Mods planned...
  1. Air Intake/Air Filter for my new A4
    By Joeyz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th July 2004, 20:15
  2. cold air intake question
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2004, 22:51
  3. Survey on Cold Air Intakes for A4 1.8T's
    By imajn34 in forum Tuning
    Last Post: 26th December 2003, 13:08
  4. Air Intake Hose Ł68
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2003, 22:32
  5. Audi 90 20V air intake
    By citino65 in forum Classic Audi Forum
    Last Post: 4th September 2003, 23:59
