    Jun 2012
    Somerset
    21
    Rear shock noise and fustration!
    3.2 quatrro sport. 53 plate
    Hi guys, I beleive to have the 'rubber ball in a plastic bottle' noise coming from my rear shocks. I have had brand new oem shocks fitted today. However the noise still remains. I have now read in a different post that 'modified shocks' were made my audi to fix this problem. Have I just wasted money on brand new unmodifed shocks? Surely post 2005 cars had the modified version, or did the set-up change in 2005? are the shocker part numbers the same for a 53plate and a 07 plate as an example? Please help!
    JPK
    May 2012
    278
    Are you sure the noise is from the shocks? Badly worn rear trailing arm bushes can cause all kinds of noises.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    402
    On top of the damper there is a little nut, if this is to come loose (which it has with mine) it will allow a little float on the damper which nocks when ever i go over a bump. Just a thought,
    Jonny
    Black Audi A3 8P 2.0TDi
    V-Maxx Coil overs | S3 Rear Spoiler | De Wiperd | TTRS Alloys | S3 Rear Bumper | S3 Side Skirts | Votex Front Spoiler | LED Ring in Fogs | LED Interior Lights | LED Number plate lights | Custom Foot well lights | DPF Removed | Green Cotton P/F | JBS Phase 2 | Pressed Plates | LED Side lights | Custom Rear Light tint | Complete Matt Black Plasti Dip | Honey Comb Front Grill | Silvertec Indicators | BOSE | Sunroof | Forge Short Shift
    Jun 2012
    Somerset
    21
    Here is an update.
    yesterday, I removed the shocks completly and drove a couple of miles, the noise remains. Today I am going to remove the coil springs and check for breakage. also I will remove the arb and test drive it without out that.
  1. Rear shocks and springs
    By sp84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2010, 11:21
  2. 1.8 t QS Rear spring broken and leaking shocks
    By Dazzer in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2010, 01:56
  3. 332 for Oem Rear Shocks and Springs Exc VAT!!!!!!
    By Forbzeeee in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2010, 10:10
  4. Rear shock in facelift and pre , what is the difference?
    By kninio in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2007, 00:22
  5. Rear shocks and bushes
    By t30gue in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2004, 10:41
