Not without modifications, the facelift ones are cut out & have locating areas to fit, prefacelift does not, the lower section is 1 piece, so you'd have to cut it out & bond it in place.
Pretty Sure you can just remove the diffuser section and replace it with a Sline one as i have seen a fair few on eBay that are compatible with all 2009-2012 A3's and you can also see bumpers that are for sale that have the diffuser removed so it should be a simple swap.
