Chris NottVolks Autos
Results 1 to 10 of 10
    Mar 2012
    278
    H&R - Creaking Springs
    Hi guys, had 50mm H&R lowering springs fitted around 10 months ago
    I've recently noticed that if I turn the wheel quickly when moving very slowly or when stationary I can hear a creaking noise coming from the front springs. It's not a clunking or banging, more a creak that sounds like it's resonating through the springs themself. I had it on my previous car too, which was also lowered. I never bothered fixing it on that.
    Just wondering if this is something I should worry about?
    Feb 2011
    Plymouth
    951
    Try covering them in spray grease. I've heard of people doing so in the past.
    Mar 2012
    278
    Thanks, will do
    Searching Google and it seems a lot of other people on varying makes and models of cars have reported the same noise when turning at very low speed (usually when reverse parking and the like) with H&R springs. From what I can gather, it's not dangerous/indicative of a fault, just an annoying quirk?
    Feb 2011
    Plymouth
    951
    I've heard it happens to lots of lowering springs not just H&R's. some lowering springs come with the coil wrapped in a plastic coating to stop them creaking. It's only because they are tightly wound and some of them touch, your standard ones would do the same if they were as tightly wound as lowering springs are.
    How are you finding the H&R's, I've got some to go on mine soon?
    Mar 2012
    278
    Other than this minor creaking, great really. I'm happy with the stance and the ride isn't too harsh
    immo's Avatar
    Stop me
    Mar 2013
    Suffolk
    270
    I heard they are not as harsh as standard S Line, can you comment?
    2006 A3 2.0TDI 170 S Line Mauritius Blue
    Bluetooth | RNSE | MFSW | BOSE | DRL | Xenon Plus | Half Leather | Heated Seats | Parking Sensors
    May 2013
    198
    Have you changed your top mounts recently? I had a creaking sound on a Saab when doing slow turns not all of the time but some of the time. The sound you are talking about sounds exactly like the same problem I had. It had Koni dampers and lowered springs. Changed the top mounts and the creaking noise stopped instantly. Dont know if its the same problem with yours Messiah but if its bugging you may be worth investigating.
    Mar 2012
    278
    Thanks for the advice. No I haven't changed them. I probably should've at the time I fitted the springs in hindsight. I think it was recommended to me, but the mechanic who fitted them said not to bother... so I didn't! Any idea how much it would cost for a garage to replace them?
    I wouldn't say it's bugging me - I'll just turn my music up . I'd probably learn to live with it if I was confident it wouldn't cause any expensive/dangerous problems in the future
    May 2013
    198
    Quote Originally Posted by SCFC_Messiah View Post
    Cost me £150 not including the parts. The top mounts for the Saab were not very expensive so I presume they wont be too expensive from Audi either. With regards not changing them and damage I don't really know but I have always been under the impression that with most car related things if you don't fix it that part will normally effect another part and then cause that part to fail too.
    May 2013
    198
    The creaking didn't originally bother me but it did get worse over time.
  1. Fix for Center Console Creak
    By hwmin in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2013, 00:31
  2. Recaro seat creaking
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2012, 19:33
  3. Eibach Springs on A3 T Sport
    By paul_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2003, 12:18
  4. where will the creaks end? Bain of my life
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2003, 08:25
  5. Audison Amps
    By Banwell in forum In-Car Entertainment
    Last Post: 13th February 2003, 23:52
