EM TuningAH Fabrications
Results 1 to 7 of 7
    Sep 2012
    21
    Replace/repair door frame seal?
    Hi all
    I've noticed the outer door frame seal is coming away from the front driver's door on my A3 8P.
    I've searched the forum but can only seem to find problems with leaky inner door seals. My problem is with seal on the outside that goes around the top half of the door frame.
    It looks like a simple fix, maybe just needs pulled of and realigned with the door frame, but I wanted to check and see if anyone has any experience of this??
    I've uploaded a (pretty poor) photo of what I'm talking about...the rubber is coming away from the top corner.
    Give me a shout if you have any advice.
    Much appreciated
    26,774
    Upload a better closer pic then we can advise if normal, ours does a little, as it has an internal seal anyway its not to much trouble, depending how bad yours is.
    Sep 2012
    21
    Cool. I'll get a better pic uploaded tomorrow, just used that one to show what area of the seal I'm talking about. It seems fine water/wind wise, but it doesn't look right as it's not flush with the body.
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    My doors make wind noise when I'm on the motorway a mate of mine who works in a body shop said they'd prolly be expensive so I knocked it in the head lol
    Sep 2012
    21
    So I took the car to a bodyshop for some advice and the guy sorted it for me. The rubber seal has a metal frame running through it so it was just a case of pulling it off the frame a bit and remoulding it. It snapped back fairly easily. It's not quite perfect, but it's pretty close.
    I noticed there was actually some wind noise at motorway speed, haven't had a chance to check if that's sorted, but fingers crossed.
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    Quote Originally Posted by nickjw2000 View Post
    Ill maybe have a go at mine too then
    Sep 2012
    Prague, CZ
    88
    Isn't this caused by the door dropping due to stress on the hinges? It's a 3 door right? ...mine has done the same, i might ask Audi how much they will charge to rectify the problem.
    2009 A3 TDI 170 STronic SLine
  1. How to replace them chrome window seals without taking out the window frame on a Audi
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th September 2012, 12:57
  2. driver side door rubber seal replacement help please
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2010, 08:30
  3. Creak from door frame
    By jbreedon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th July 2005, 13:12
  4. Front door frames scratched from seal
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2005, 18:20
  5. button on drivers door inner seal...
    By Welch in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2005, 18:06
