Sky InsuranceAH Fabrications
Like Tree1Likes
  • 1 Post By Chillout
Thread: 3.2 DSG Quattro Faulty Camshaft Adjustor
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    361
    Hi guys,
    just wanted to check if anyone has come across this before, bought this 2006 A3 Quattro DSG with a misfiring fault, apparently the previous owners had this problem, got the chains and tensioners changed and gave up. Fault code was incorrectly correlation with cam and crank, when I looked at the measuring blocks I found that the inlet cam timing was 40 degrees out, so stripped it down and not surprised to find the inlet cam was not lining up. When I further investigated the inlet cam could be move an 1/8th or a turn while the chain was still holding the sprocket.
    Taken both the camshaft adjusters off and the inlet one can be moved, yet the exhaust one does have some play but only about 0.5mm
    see pics below of the cam adjusters with the insides turned fully anticlockwise, marked (pic 1) and then turned fully clockwise, you can see that the inlet cam adjuster on the left has CONSIDERABLY more movement (pic 2).
    Has anyone come across this before? Doesn't seem normal to me.....
    If my understanding is correct the cam adjusters should lock in place and when oil is injected this would unlock and vary the timing.
    p.s. strainer for valve adjustment body was clogged and torn.
    thanks in advance.
    Apr 2013
    Aberdeenshire
    592
    Hi try this link http://sandbox.enjoybeing.net/veedub...self_study.pdf my 3.2 idles rough it does my head in but has no codes would love to fix it but I think it's a money pit.
    autolatry likes this.
    Feb 2006
    Vale of Glam, U.K.
    13
    Hi
    I'd try R32OC | VW Golf R32, Golf R and all VW R Vehicle Owners Club and do a search under camshaft.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    faulty hydraulic link device
    Feb 2011
    361
    Thanks for the comments, believe ice resolved it as the strainer to the valve adjustment body was blocked, going to rebuild the adjustors and put it back together.
  1. 3.2 DSG Quattro Service Schedule Sheet
    By Jumpjim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2011, 15:10
  2. What's the final word with non DSG/quattro & S-Line?
    By schem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2005, 20:29
  3. A3 2.0T FSI Sport DSG/Quattro - no Dual Exhaust?
    Last Post: 5th October 2004, 12:14
