EM TuningJMB Retrofits
    May 2013
    Central London
    Lightbulb RNS - E retrofit on my 2005 Audi assistance required.
    I have retrofitted the RNS - E on my early 2005 Audi A3. It have the Symphony concert, single DIN.
    I have converted the single din cage in the centre console to a double din as required with the relevant parts.
    I then bought the audio adaptor to connect the RNS E however some of the pins need re-adjusting as i get a Nav, radio and right speaker error displaying on the VCDS.
    The original wires from my vehicle seems minimum compared to what comes out of the RNS E. looking carefully at the pins on both ends, either some do not meet or possible they are not correctly sitting in the right place.
    The device actually works fine when connected with all speakers working i guess. The phone module also works. The reception to the radio is defo not strong as it used to be with the previous system.
    So.....i need some help and advice.
    Here are some pics to help you understand.
    Old Audi Concert audio PINs diagram - this is how it came out from the factory.
    So if you can help me out i would much appreciate it.
    Mar 2011
    Cleveland
    970
    I did exactly the same conversion and all was great from the off. The difference in the number of wires doesn't matter. Do you have Bose?
    27,038
    As long as you used the correct antenna adapter & rns antenna connections aren't damaged, then shouldn't make any difference to the radio.
    May 2013
    Central London
    Yes I have Bose installed. Possibly need to move some pins around.
    The antenna seems to attached correctly. I saw a few other threads on here regarding the antenna amps that require changing to get full strenght frequency.
    I did notice something else. Once Im listening to radio, if I have my phone plugged in via the cigarette lighter to charge. (Genuine car carger) the radio reception has an interfearence.
    I can only asssume this will be down to the antenna amp or something?
    27,038
    Its an 05, antenna amps are irrelevant.
  1. RNS-E retrofit service Audi A3 2009
    By deek19790 in forum Satellite Navigation
    Last Post: 13th October 2012, 08:30
  2. 2005 Audi A6 4.2 any owners.
    By TonyDaTool in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th November 2004, 00:20
  3. 2005 Audi RS4 finally breaks cover
    By imported_ndrummond in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 26th October 2004, 20:04
  4. MOVED: 2005 Audi A3 Sportback
    By porker968 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2004, 23:11
  5. Audi Assist story and 1.8Ts/S3s stil in warranty
    By evotista in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2004, 15:09
Tags for this Thread
