Sky InsuranceVolks Autos
Results 1 to 7 of 7
    Oct 2012
    65
    Side turn signal lights
    Hi all,
    I've just noticed that neither of my side turn signals are working (ones on wings)
    ive check vcds and all seems fine the option for side turn signals is on!
    now I don't actually know of these have ever worked!
    ive also checked bulbs
    its a 2007 a3 2.0tdi sline sportback
    cheers
    27,099
    Module 09, byte 22, bit 4 where there’s an option for Speed Dependent Trunk Locking Active, make sure this isn't enabled.
    Oct 2012
    65
    Got rather excited then that I may eventually have an answer as it was enabled but after un-ticking it still no joy
    27,099
    Have you done a lock/unlock then test again as sometimes needs a reset, plus check bulbs, show us a log of module 09.
    Oct 2012
    65
    Yup tried that, I have however just noticed that when I unlock the car and the leaving home lights come on so do the side turns!
    How do I log modual 9?
    Oct 2012
    65
    Actually just double checked and only the drivers side lights when I unlock!
    ive taken a screen shot of the coding but can't seem to upload! Also in the measuring block under side turn it just has a dash!
    27,099
    Just show us the coding for module 09, screen dump of your pc when logged into module is good enough, hopefully.
  1. Orange signaling light removal
    By Hryco in forum General Technical / How To
    Last Post: 14th December 2004, 06:31
  2. Turn Signal Problem
    By wascal in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th December 2004, 21:27
  3. Orange signaling light (Front Corners)
    By Hryco in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2004, 21:14
  4. Broken Turn Signal Replacement
    By ozzy in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th December 2003, 17:16
  5. Chrome Turn Signal Bulbs
    By juhko in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2003, 22:40
