JMB RetrofitsSky Insurance
    Mar 2012
    46
    Sportback to 3 door boot panel? Stealth Install.
    Hi
    I have been looking Into a andy mac stealth install for a while now. I have a sportback and would have to deform the boot panel for the sub to fit, also I would have to find a stealth install for the amp. What I was thinking of is buying the boot panels from a 3 door as these have flat sides, allowing more room to fit the sub behind, and the amp on the other. Would this be possible?
    Any advice or suggestions would be grateful
    Rich
    27,099
    The drivers side has a sunken/indented area where the amp usually sits, depending on your amp size, then this could be utilised, but may require a new side cover that isn't indented.
    Mar 2012
    46
    Thanks,
    Thats what i was thinking. Do you know if the 3 door panel would fit? As i believe this is not indented.
    Cheers Rich
  1. B5 armrest/console/cruise control/door/boot lid trim
    By acf8181 in forum For Sale/Wanted - Audi Parts
    Last Post: 6th October 2011, 15:42
  2. Boot panel (exterior) s3
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2011, 11:50
  3. Door Sill Panel Kick Plates
    By dalespitfire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2010, 23:13
  4. 2007 AUDI A6 AVANT BOOT PANEL REMOVAL
    By nigel1955 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd November 2009, 13:01
  5. Boot panel removal
    By freddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2007, 12:23
