JMB RetrofitsEM Tuning
Results 1 to 15 of 15
    Filthy Oil Burner
    May 2013
    UK
    35
    RNS-E + BOSE = spilt eardrums
    Popped a RNS-E into my car and with the Bose sound system it is DEAFENING, and not in a good way, the chick from the Satnav voice is breaking me.
    I've tried going through the system to turn down the volume but its on its lowest settings, if I were to plug it into VCDS will I be able to turn it down further or do I need to invest in earplugs?
    Its not just me being weak, after nearly five years in the army my left ear is pretty rubbish anyway, but its still really loud.
    Then: '05 A3 3.2 Quattro DSG
    Now: '10 A3 2.0 TDI Quattro Black Edition - Mod thread to follow
    27,126
    All the volume controls are within the setup/sound menu, so I cant see how the voice can be a problem overall & you can easily adjust treble/bass & lower volume if need be, never been an issue I've come across as long as installed properly.
    Filthy Oil Burner
    May 2013
    UK
    35
    On my iPhone app it is reading at 95 decibels which is just less than a chainsaw! I'll try adjusting all the treble etc down but the normal radio volume doesn't affect the Nav voice.
    immo's Avatar
    Stop me
    Mar 2013
    Suffolk
    276
    When the nav is speaking, use the volume adjuster.
    2006 A3 2.0TDI 170 S Line Mauritius Blue
    Bluetooth | RNSE | MFSW | BOSE | DRL | Xenon Plus | Half Leather | Heated Seats | Parking Sensors
    Filthy Oil Burner
    May 2013
    UK
    35
    Quote Originally Posted by immolator View Post
    That doesn't turn Her down, just the radio volume.
    Jan 2011
    687
    Hsve you tried turning done the volume while she is speaking ? Also did you get the current cable adaptor there s a Bose and a none Bose version.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    immo's Avatar
    Stop me
    Mar 2013
    Suffolk
    276
    Then something isn't right I can tell you that much.
    Filthy Oil Burner
    May 2013
    UK
    35
    Quote Originally Posted by Cabbyfan View Post
    Its a 2012 RNSE that has been working fine, Plug-n-play with no dramas apart form the volume. Didn't realise there was a Bose specific cable, what would that connect into? The only other thing that I thought the RNS-E needed was the GPS antenna which is now stuck under my dash.
    Jan 2011
    687
    The Bose amp in the boot is connected differently than in cars without Bose, so there are definitely 2 different cable harnesses. That being said if its just the nav voice that's too loud I'm not sure why the cable harness would make a difference.
    Filthy Oil Burner
    May 2013
    UK
    35
    Everything that I unplugged from the Symphony got plugged into the RNS-E (in addition to the GPS receiver), theres a little volume variation between radio stations but the satnav chick is seriously loud.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    They aren't plug and play totally. The RNS-e needs to be coded for Bose for one and one of the wires on the plug needs to be moved from pin5 to 7.
    The volume should be adjust while the Nav is talking though... If it doesn't then the unit has an issue I would suggest.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Filthy Oil Burner
    May 2013
    UK
    35
    Thanks for the advice, I'll adjust the pins and get it coded next time its in with my fixer.
    Sep 2009
    135
    Jumping on the back of this, is there a way to set a low start up volume for the radio and media player hen turning on the ignition?
    Ask admin to advertise here
    Jan 2012
    SW London
    794
    If u got to nav menu and find settings or i think press the settings button along the bottom u can manually adjust the nav volume, it may be under a volume options menu. As for excessive noise elsewhere u need to fine tune it i reckon. What audio input are u using? Cos if ur using aux u need to disable any equalisers on the device ur using otherwise they double up with the equaliser in the rns-e and then it sounds like poop.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by soulsurfer View Post
    Short answer is no. If you search the forum this has been discussed before as an annoyance of the 8P A3.....
    Scott
  1. RNS-E + Bose + Multi function steering wheel ..... adding Bluetooth ?
    By GavConner in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd October 2012, 13:11
  2. RNS-E Bose Coding
    By kolash in forum In-Car Entertainment
    Last Post: 13th June 2012, 17:59
  3. RNS-E BOSE / GALA setting S3 8P
    By Whiteatom in forum In-Car Entertainment
    Last Post: 9th July 2008, 23:04
  4. Audi Sat nav plus RNS-E Bose HELP !
    By Whiteatom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2008, 21:55
