Like Tree3Likes
  • 3 Post By S3Alex
Thread: dump valve on my S3?
    Mar 2013
    Blackburn, Lancashire
    17
    Hi everyone
    i put a let off dump valve on my S3, replaced it where the normal one goes sounds **** but runs o.k.
    I then cut into my throttle body pipe and put it in there sounds mint but brings engine management light on and revs idle up and down
    Can anyone help me with where to put it so it sounds good?
    cheers
    Reload's Avatar
    Bird is the Word!
    Jul 2010
    Midlands
    367
    I'm assuming by sound you mean a dump to atmosphere type valve.
    VAG TFSi engines need a recirculating valve, they will no work well on atmospheric dump valves as the MAF will be throwing back false readings, hence the engine management light. Long term this could damage your engine as the car will constantly be running too lean or rich as it attempts to compensate for false air readings. In short, get a recirculating valve back on sharpish.
    I think forge do a form of blow off adapter which fits onto their recirculating valve but not sure. This could be what you need
    S3 8P2 Ice Silver, RNS-E, Bluetooth, iPod connection, Adaptive xenons, black styling pack, sunroof, privacy glass
    Mods since owned: Milltek Resonated TBE, Neuspeed P-Flo, Loba HPFP, Sachs Clutch with Loba SMF, Unicorn Motor Developments custom remap, brakes + suspension upgrades, LEDs internal and external, more interior kit
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    Quote Originally Posted by barlow S3 View Post
    Hi everyone
    cheers
    Hi...as Reload says,your car's ECU is now having trouble working out airflow,as you've introduced a great big leak into the system effectively.
    If you absolutely have to have something that makes noises,then this is what you need....
    Forge Motorsport | Alloy Fabrication
    Of course,now you need a new throttle body pipe,and you need to replace the Diverter Valve.
    Luckily Forge will sell you all of the bits you need...
    I know it sounds like lecturing,but you really should find out how a particular engine measures ariflow etc before chopping up the induction system.
    Oh...and I almost forgot...put the dump valve in the bin,before you damage your engine.
    NHN, wuta3 and chilly like this.
  1. Best Diverter Valve/Dump Valve
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 13:11
  2. Dump Valve/recirc valve?
    By Jinx in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2003, 23:53
  3. Blow off valve or Dump valve ?
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2003, 19:18
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
