AH FabricationsBadger5
Results 1 to 10 of 10
    Sep 2012
    50
    A3 brake upgrade, new hubs required ??
    would i need to change my front hubs on my 2007 a3 1.9 in order to upgrade my brakes ?
    currently on standard 280mm discs and calipers but the 2.0 a3's use different calipers and slightly bigger discs 288 i think.
    so would i need to use the hub etc from the 2.0 or can i just swap the calipers and discs over.
    ideally looking to get the bigger 312mm discs which i beleive use the same caliper but also use carriers.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    Yes, you need new hubs. Your curent front hubs have the caliper carriers built-in. You need other carriers for bigger brakes.
    Also, your strut diameter I believe is 50mm now and the hubs from 2.0 TDI are for 55 mm struts. When buying the hubs you should check this aspect too.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Sep 2012
    50
    thanks johnny bravo, why is nothing just straight forward ??
    TDI140's Avatar
    May 2011
    1,356
    I just bought golf gti edition 30 calipers with carriers and new discs which are 312mm then got the mechanic to swap them over thats it also added brembo pads and job done work really well with my car but still wanting mercedes AMG full brake set up about 380mm on front :-P lovely lol
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    6+1 Gears
    Jun 2009
    Romania
    797
    Yes, on 2.0 TDI is much easier. I have the S3 ones on mine.
    Sep 2012
    50
    i knew i should have got the 2.0
    6+1 Gears
    Jun 2009
    Romania
    797
    Anyway, start by checking what other engine comes with 50mm struts and if it has the front brakes at least 288mm. These have the separate hubs and carriers and you won't have to change the struts.
    Sep 2012
    50
    not sure which engine would come with 50mm struts , are you suggesting vw or skoda models ?
    6+1 Gears
    Jun 2009
    Romania
    797
    some 2.0 FSI I think that came with 50mm struts.
    Sep 2012
    50
    bset get my vernier gauge out
  1. 312mm brake upgrade for sale complete with nearly new discs and pads
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2011, 22:00
  2. New ears and bigger brakes & upgrades
    By Purple Princess in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2009, 23:11
  3. New S3 SB ordered - Brake Upgrade ?
    By Spin140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2009, 13:31
  4. New interior required
    By Simon in forum General Technical / How To
    Last Post: 19th February 2003, 11:20
  5. S3 Brake Upgrades - not Porsche/Brembo
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 17:05
