AH FabricationsSky Insurance
    Dec 2012
    47
    Few problems... Advice please.
    Hi guys, noticed recently when starting my car in the morning, it takes 2 attempts to start over, and it idles rough for a few minutes..
    secondly, anytime I stop at lights, or pull away from stop I hear a knock from the rear, could this be brake pads sticking?
    Cars a 20t with 55k on clock. Are these common issues?
    Any help would be great.
    P
    Sportback owner
    Apr 2007
    France
    486
    Hard to say without doing a VCDS scan and looking for any fault codes. See if you can find a member nearby with VCDS. There is a map on this site showing the locations of members with VCDS and they usually will be very helpful (have beer ready). On the knock, try coasting to a stop without using brakes, then pull away normally. If you hear a knock it may not be brakes at all. Could be a broken rear coil spring, which several members have reported. Could also be a suspension bush. Fortunately not too expensive to fix. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Dec 2012
    47
    It's a dsg so it's a bit tricky coming slowly to a stop. I'll give it a go. Someone mentioned the lambder sensor for the rough start??
    is there any other issues for 55k on a petrol turbo engine?
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Pcv failing would cause rough idle, might be worth changing it for the newer version it's only 45 quid.
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
  1. More S3 headlight problems... Advice please...
    By AJD S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2012, 00:40
  2. Engine problem, Advice please
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2012, 19:25
  3. Strange temp problem advice please
    By macpdm in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2011, 23:02
  4. Door lock problem, advice please?
    By Trigger in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2010, 14:50
  5. A few problems, Help please
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2005, 22:13
