EM TuningChris Nott
    May 2013
    6
    Door Unlocking Problem
    Hi Guys,
    I have just picked up a 2005 Audi A3 TDi 140 SE Sportback with DSG but I have a couple of problems which I wonder if you can help me with:
    1. The drivers door doesn't unlock with the remote and sometimes only the rear doors unlock. This means I have to climb in the car and manually open the door using the internal door handle. Weirdly the drivers door never unlocks but the other 3 doors vary on which which ones unlock.
    2. The car makes a rattle noise when on boost between 1.5-2k rpm.
    Any help or advice will be greatly appreciated as I really love the car other than these niggles.
    Nov 2012
    29
    Quote Originally Posted by adzpz View Post
    Hi Guys,
    Hi mate.Had the same problem with drivers door on my 2009 A3 TDI 170 BE
    Went into Audi under warranty and they replaced broken wire in door panel.
    Hope this could be a help to you.
    Mar 2011
    Cleveland
    871
    Won't the driver's door open with the key? Easier than climbing across!
    May 2013
    6
    Quote Originally Posted by fangio View Post
    Unfortunatly not, it's like the unlock part of the central locking is dead for the drivers door. Weirdly it locks fine with the remote??
    Any idea where the wire was located that Audi repaired?
    May 2013
    6
    Took it to my local garage and they removed the lock and it appears that the grease used in the door lock motors has hardened with age preventing them working correctly. They clean the motor up and lubed with a lighter oil and it appears to be working perfectly now
  1. Door Unlocking Problem..
    By jb0o in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2010, 08:22
  2. Door unlocking problems
    By dcg in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2009, 08:46
  3. Door closing problem
    By Aurom in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2004, 07:57
  4. Remote power door lock problem
    By ct1211 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th April 2004, 16:21
  5. Door Latch Problems!!!!
    By jondana in forum TT/TT-S/TT-RS Forum
    Last Post: 20th February 2004, 10:39
