Results 1 to 10 of 10
Thread: Spark Plugs
    May 2013
    7
    Spark Plugs
    Hello All,
    I'm about to map my '05 A3 2.0 TFSI Quattro - 68K - and wondered if anyone could give me any advice on spark plugs.
    I've changed the DV to the uprated piston type and have an ITG panel filter in but am a bit unsure of which plugs I should use for a stage 1 map? Is replacing the coil packs a good idea too?
    Any advice would be most appreciated.
    Sam
    Dec 2011
    226
    Just put standard plugs in it and if its running fine there should be no need to replace the Coil packs mate
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    As above...current advice is to use stock plugs,but change more often than the Audi service schedule,and certainly if you get any misfires.
    May 2013
    7
    Perfect, thanks.
    I don't suppose you know the plug number off the top of your heads?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Quote Originally Posted by samsonQ View Post
    Perfect, thanks.
    Sorry....I usually leave all the oily stuff to the people who do the hard work,but someone will be along shortly with the right answer!
    Jan 2013
    glasgow
    23
    Pt no: 06H 905 611 Thats for 06 plate so double check to be certain
    Turbo jay's Avatar
    Leather repair specialist
    Jul 2012
    North west
    548
    Quote Originally Posted by garythedrummer View Post
    Yea as Gary said these are the ones
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    I tried running some super cool ones or some rubbish that I bought from a tuning site and they lasted only a few thousand miles. Started with the odd misfire and it got steadily worse.
    I went into Audi and had a chat with the parts guy, the OEM ones are actually one of two brands. The ones I got were NGK PFR7S8EG.
    They've lasted for so long that I can't remember when I got them. Well over a year ago anyway.
    8P2 S3
    May 2013
    7
    Brilliant, Thanks for that.
    Jul 2011
    Bucks
    161
    I've just got some NGK iridium spark plugs for my S3, ordered on Sunday from Camskill and arrived Tuesday first thing - great price and great service !
    Revo Stage 2 -Miltek - Sachs Clutch
  1. spark plugs
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2004, 17:02
  2. Spark Plugs
    By Bradley in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2004, 19:23
  3. Misfire and Spark Plugs under warranty
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2004, 10:39
  4. spark plugs....???????.....
    By smudgy57 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 17:33
  5. spark plugs
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2004, 01:23
