Chris NottVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 45
    May 2013
    7
    Aftermarket stereo, rear speakers and amp very low volume
    Hi all... i have spent 2 solid weeks going from place to place looking for someone who can sort out my problem... but no joy. I have an audi a3 sportback which originally had a symphony double din radio/cd installed. I decided to install an aftermarket gps/dvd/bluetooth etc stereo. Everything works great... but the back speakers and sub are half the volume of the front. When i use the fader towards the rear i get better sound but means i must put the H/U's volume up max! However no distortion.
    Is there anyway to remedie this without loads of rewiring and expense? Is there no volume on the factory amp? I dont mind keeping the factory sub and amp.. but just want the same volume all round without boosting volume to max! any help is much appreciated!
    Jan 2012
    SW London
    794
    Can you detail every adaptor u used? what stereo did u install aswell?
    I've done a fair few audi installs and dependant on what adaptor u've used there may be ways around it, some come out louder than others weirdly enough. I've been told, not sure if its true cos i've found no evidence to back it up, that u can control the amp gain somehow on the factory amp, so u could in theory boost the gain level to compensate for the low volume input.
    May 2013
    7
    Thanks for the reply...
    I bought a multimedia unit from Eonon. Unit is great... works perfectly. The guys at halfords fitted it. They just used the audi (iso i think its called) adapter... however ive just seen this... which is different to the one they fitted? do you think this is the one i need.. sounds like it from the description? Halfords | Autoleads PC9-404/PC9-410 - Audi ISO Lead/Harness Adaptor
    by the looks of it.. they just fitted a standard one in mine. rather than the one designed for the amp. So might go for this? what do you think?
    Jan 2012
    SW London
    794
    If u check ur receipt it should tell u what the part number is. What system do you have in ur car? bose, non-bose? Under the assumption that you took a double din out to put this double din in you would have needed a quadlock adaptor not an iso, although something early model a3's used ISO's. What year is ur car? And what stereo did u have before that. Whereabouts are u based?
    May 2013
    7
    im from newcastle. the stereo was factory... symphony (double din). My car is a 2004 a3 sportback. It has rear amp and sub... so i guess this lead will work. Also the head unit i am installing has phono connections for subs, rear left and right. so i think this might work. If not quad will be next attempt. The one that they fitted which is wrong i think... is PC9-401... And the one i am looking at which i hope will solve the problem... is PC9-404 / PC-410
    Jan 2012
    SW London
    794
    It'll be ISO only not quadlock. U can try the 404, but im not sure if that will solve the problem. U could run an rca signal booster (pc9-460) with this tho
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Jan 2012
    SW London
    794
    Also the 410 is for fully amp'd systems whereas the 404 is for half
    VCDS User
    May 2013
    7
    I see... I'm not following? It says on the site (pc9404 / pc9410) ?
    I presumed is was just the two seperate parts? Does that mean the one from halfords fits both?
    So I just don't connect the front Phono's?
    I remember when fitting a stereo was easy!! Ha
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    What is the watt output from the stereo? May be the stereo can't push out enough sound
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    May 2013
    7
    It's 50w output. From the front it's very loud!! Rear is only problem I think because of the lead. Where as this one is specifically for the symphony half amplified. So going up this morning to sort it out. I'll let you know if it worked. Thanks for your advice and help
    Jan 2012
    SW London
    794
    Quote Originally Posted by Snaithy View Post
    The guidelines on the website are very vague. The 404 and 410 are two completely different leads for two different applications. 404 is for half amp'd iso systems, 410 is for fully amp'd iso systems. So since urs is only rear speakers and sub, u need the 404. Its exactly the same as the 401 except it has rca's instead
    VCDS User
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    Things work so much easier when you just use the connects2 cables instead! these crappy autoleads adapters always cause issues!
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    May 2013
    7
    Yeah i was i'd known about connects2 before i bought all the other ****. bought that lead.. same issue... so have bought the pc9-460 booster which you mentioned. so will fit that when it arrives
    Jan 2012
    SW London
    794
    Get a good power feed that isnt from the stereo loom. Check out my guide for wiring an ignition source if need be.
    VCDS User
    May 2013
    7
    Decided to start over.. Took all the auto leads parts out. The booster just boosted all the engine noise etc.. So now ordered the connects 2 lead that has the active 2 channel box and gain controls. Hopefully this will work
    Nov 2013
    16
    Hi,
    I have the same problem I brought a connects 2 iso lead but realised it wasn't simply a plug and play so had to have it fitted. It needed running an extra wire for power source I think.
    The lead I used was a connects2 one, but it is exactly the same as this pc-9-401.
    My front speakers are fine but the back speakers are really quiet. Now I could use the fader to the back but it just really isn't the same as before
    did you manager to fix your issue? If so how?
    Many thanks in advance
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    the connects2 leads do not need extra wires for power. i have used hundreds of those leads on installs that i have done and none have needed it. i would guess that you bought the wrong lead for your setup and thus needed some modification to get it to work.
    also the link to the ebay wires you sent are the autoleads loom
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Nov 2013
    16
    Quote Originally Posted by Ash187 View Post
    The lead I brought was a connects2 CT20AU09 which is the same as the auto leads one so I just sent that link. This one difinitely needed modification.
    The quesion is what do I do next to resolve this issue? Is there a way I can wire this right or do I need to buy a new connects2 lead?
    Many thanks
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    well just searching for CT20AU09 brings up this as the first result: Buy CT20AU09 Audi Rear Amplified Active Harness Adaptor
    That link clearly shows that harness is for the A3 8L. what car do you have and what year is it?
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Nov 2013
    16
    I searched for the same on their website and it says it's for an audi A4
    Connects 2 Car Audio Systems, Car Stereo, Car Radio DAB Stereos, Car interface adapters and accessories > ProductInformation
    I have a 2005 Audi A3 2.0 TDI.
    Nov 2013
    16
    I checked on their site and it shows it's for an Audi A4
    I've got an Audi A3 2.0 TDI 2005 plate
    andyam's Avatar
    Jan 2011
    Bristol, United Kingdom, United Kingdom
    360
    I have a connect2 lead for 8p iso if you need it. It's used but I'm selling my a3 now so no longer need it. Pm me if you want it. Cheers. And ash is the man with this stuff helped me loads with my install!
    Now: Audi A4 B8 2.0 TDi SE - Silver, Bluetooth, Parking Sensors, Auto Lights/Wipers, Auto Dimming Mirror, Hill Hold Assist.
    Before: Audi A3 8P2, 1.9TDi Special Edition, Silver,
    Armrest, MY09 Rear Lights, R32 MK5 Alloy Wheels 18" Gloss Black, Gloss Black Sline Grill, Windows Tinted, Carbon Wrapped Trim, Wind Deflectors, Alarm Beep, LED Interior and Number Plate Lights, Cupra R Splitter, S-Line Springs, footwell lights, S3 Pedals.
    Nov 2013
    16
    Andyam, I'm not sure if I need it and if it will fix my issue. I've used CT20AU09. which one do you have?
    Also i'm not sure when you will see this post because for some reason my posts aren't showing up until approved by a moderator. Mods please unblock this and let me post straight away, I promise I won't post any profanity lolll
    Nov 2013
    16
    I have an 2005 audi a3 2.0tdi. I used the CT20AU09 but maybe I need the CT20AU10?
    Also I am thinking of instaling a sub and amp so do you think this will fix it? FYI it's a vibe active sub.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    This is the one you need!
    Connects 2 CTSAD002 - Audi A3 / A4 / TT Steering Wheel Control Interface Adaptor
    you have to remember that the older cars were not canbus and so the cheaper cables worked. on the newer cars you need to get the proper canbus cables. count your losses with the wires you have bought and just get the one i have linked. it will work with all the things you want.
    is this the same one you have Andyam?
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Nov 2013
    16
    Thanks Ash, but I don't have the new quadlock connection or any steering wheel controls, I have the iso and red mini iso. I brought a similar one and it did not fit at all as I don't have the new quadlock connection.
    What about the CT20AU10, will this not work? Is there any way to modify the CT20AU09 connector?
    Also, I'm going to be adding in a active sub tomorrow, so will this solve my problem ? Can I just run the speakers off this amp, or should I get them working properly first by modifying the above cable?
    Thanks for your help.
  28. #27
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    Ok where in the link did it mention it had a quadlock? the one you bought before may have been a quadlock version but that i because you bought the wrong lead... im starting to see a pattern here.
    I have already advised multiple times which lead will do the job! i have even given you a link to the sellers site in which i buy mine from (not to mention the same lead i have in my own car)
    now its up to you what you want to buy and how much time you want to spend on it.
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  29. #28
    Nov 2013
    16
    The big block on the adapter you sent a link to, I have no where to connect that to. I also have no steering wheel control so why would you think this is the right lead?
    I've already spent quite a bit on the leads and fitting cost so I'm reluctant to spend any more, if there is a way to modify the one I have.
  30. #29
    andyam's Avatar
    Jan 2011
    360
    Yes ash this is the lead I have mate.
  31. #30
    andyam's Avatar
    Jan 2011
    360
    H_audi the block is he canbus bit. You still need it. I don't have steering wheel functions either but used it and worked. I initially thought I didn't need the block. But you do. Just don't plug the other cable on the other side. Sorted
  32. #31
    Nov 2013
    16
    Quote Originally Posted by andyam View Post
    Oh ok. So there is no simpler cable without the steering wheel bit which may be cheaper? Will this work simply as a plug and play solution?
  33. #32
    andyam's Avatar
    Jan 2011
    360
    It is plug and play dude. And also not that I know of. You could do a hard wire which for me was too much effort and ballache....
  34. #33
    Nov 2013
    16
    If I could do a hard wire, that would be much better right now, as I have already spent nearly £80 on cables and adapters already, so really don't want to spend any more if I can help it.
    if you have any links that might help with the wiring, that would be much appreciated dude.
  35. #34
    andyam's Avatar
    Jan 2011
    360
    I didn't look into it too much. Have a search on the threads mate should be able to pick it up.
  36. #35
    andyam's Avatar
    Jan 2011
    360
    Question...why don't you refund some of the cables? Surely they aren't past the 28days refund policy?
  37. #36
    Nov 2013
    16
    They were cut/modified to work as plug and play didn't power up the stereo and also I paid for fitting too, which i can't get back.
    I think the below link seems to be the right one and it's not too expensive, but again I'm not sure so need to confirm from someone already used it.
    Idealy, I wish there was a way I could modify my current one...
  38. #37
    andyam's Avatar
    Jan 2011
    360
    That still won't work I don't think....as ash said CANBUS CANBUS CANBUS. That's the problem
  39. #38
    Nov 2013
    16
    Alright Ash, seems you know what you are talking about, so if I get this lead it would be solely based on your advise here.
    I just have one question for you; where would all the connections go, as all I have is the ISO and red mini ISO, as pictured in the link below.
    Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
    Is there a fitting guide you can point me to?
    Pic is upside down, but I guess you still see the connectors so it's all good.
    Thanks for your help!
  40. #39
    Nov 2013
    16
    Also Ash, this is a very similar one to what you suggested, but it looks liek the block on there fits iso and the red mini iso...I could be wrong and maybe am so feel free to correct me
    Connects 2 CTSAD003 - Audi A3 / A4 / TT Stalk Steering Wheel Interface Adaptor
    EDIT:
    I've been doing some more digging and I think the above is the one you may have been trying to direct me to, as the one you suggested first IS quadlock connector. It may not say it on the dynamic sounds site, but searching the same part number on another site says it's quadlock, see below.
    Connects2 CTSAD002 Audi A3 2005> Fakra/Quadlock [Connects2 CTSAD002] - 40.00 : Car Audio 4 Less, Car Audio System
    Is that right? Easy mistake to make I guess, they are very similar.
  41. #40
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    do this, give the guys at dynamic sounds a call and tell them you want the iso version of the connects 2 steering wheel harness adapter... they will send you the right one. if you have a look at this link you will see they do loads of them adapters with slight variations on each Audi - Steering Wheel Control, Stalk Control Adaptor, CAN BUS Steering
    I was 99% sure that the one i first posted was the right one as they have listed it for 2003+ cars.... quadlock only came in sometime during 2006/2007
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  1. right fitting iso lead to power rear speakers and amp
    By pirate in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th July 2011, 10:33
  2. Fitting aftermarket head unt speakers and amp
    By rhubarb4 in forum In-Car Entertainment
    Last Post: 1st May 2011, 20:35
  3. Replies: 4
    Last Post: 17th November 2010, 00:15
  4. Rear speakers and Sub not quite right
    By kayvee in forum In-Car Entertainment
    Last Post: 12th July 2010, 20:07
  5. After Market Stereo Rear Speakers Buzzing
    By Nemesis668 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2008, 09:26
Tags for this Thread
