Volks AutosAH Fabrications
Results 1 to 12 of 12
    37
    37's Avatar
    May 2013
    Area 51
    118
    Audi A3 07 Reg - NO Engine Mgmt Light but Code P0171
    Hi guys,
    I was hijacking someone else's thread and the replies I was getting weren't making sense so I thought I might as well start a thread and ask once in for all.
    I recently purchased a stock A3 with absolutely No mods at all and everything is absolutely fine with the car. I took it to one of these free health checks. They said everything is fine but the OBD came up with error Code P0171. The guys there said it best to change this sensor, which I now believe is the O2 Lambda sensor. The car runs absolutely fine, there is nothing unusual. Although I wastold that the mpg might be affected because of this. I managed 225 miles in half tank around London, which I think is pretty good.
    My question is if there is no engine management light and the OBD came up with that error, how would I know it is an error for sure? I wouldn't have known about the error if the guy had ran the OBD and would have been driving normally. I think the light does come on when I switch on ignition and then goes off, like other lights do when you switch on ignition, so in other words its not been disconnected or anything.
    Moving on, if it is an error indeed and I wanted to get it changed, is this what I will need? I was told it is an O2 Lambda sensor and this is what I can match. Also, how would I know about this error in the future? I mean I don't have an OBD and I can't just pop into garages every now and then just for fun to get my car OBD'd!!
    Where can I locate the MAF to clean that thing? I can't find any videos for A3
    Thanks for all the help.
    Oct 2012
    Warrington, North West
    986
    I'd just get it scanned with VCDS before wasting money
    37
    37's Avatar
    May 2013
    Area 51
    118
    Quote Originally Posted by Mikemc View Post
    Thanks for that Mikemc. Anyone around West London Area with VCDS
    One thing I should also add is that it does say on the report "Intermittent" which would mean it's not consistent.
    Jun 2011
    Great Melton Norfolk
    1,348
    Have a look on the VCDS users map to see if there is anyone near you who can scan it.
    Jan 2012
    SW London
    794
    What engine do u have? And where r u located?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,474
    could just be an old code
    id clear it off and recan in a few days see if it comes back
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    was fitted with a crap air intake by previous owner and potencially remaped etc
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    37
    37's Avatar
    May 2013
    Area 51
    118
    Thanks for replies chaps. Sidhu88; I've a 1.6 Petrol. Pl check PM.
    Quote Originally Posted by RedDejavu View Post
    The car has Full Audi Service History right from the start so I wouldn't imagine that would be the case but the intake could have gone !!
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    could be loose piping after MAF section or you need to check if MAF sits in properly. Good to check cam follower too.
    Now:
    37
    37's Avatar
    May 2013
    Area 51
    118
    Pardon the ignorance but with only 3 weeks with my first Audi - I can't locate the MAF ..
    37
    37's Avatar
    May 2013
    Area 51
    118
    Hi guys,
    Thanks to Ash187's help, I've now got the log.
    Could someone please let me know if it is indeed the O2 lambda sensor that I would need to change? If yes, where/how do I find the part number. If not your input would be appreciated.
    Please bear in mind that there is No engine management light on and there isn't anything wrong/alarming with the car when I am driving it around. Funny enough, it says Fuel level too low at the end when I've got half a tank of Fuel.
    Control Module Part Number: 06A 906 033 EH
    3 Faults Found:
    16555 - Fuel Trim; Bank 1
    P0171 - 006 - System Too Lean - Intermittent
    Freeze Frame:
    Lambda: 25.0 %
    Lambda Factor: 1.008
    Voltage: 0.440 V
    Speed: 0.0 km/h
    Lambda: 25.0 %
    Lambda Factor: 1.000
    Voltage: 0.440 V
    Speed: 0.0 km/h
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1103 - 006 - Performance too Low - Intermittent
    Freeze Frame:
    RPM: 608 /min
    Mass Air / Rev.: 92.7 mg/str
    Resistance: 0.00 kOhm
    Hex Value: 0x0001
    17658 - Fuel Level too Low
    P1250 - 000 -
    Freeze Frame:
    37
    37's Avatar
    May 2013
    Area 51
    118
    erm - anyone chaps? :/
  1. Engine Management Light + Fault Codes - Help
    By leeds2592 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2013, 14:05
  2. HELP!!audi a3 tdi 140bhp diesel!engine managment light
    By audi_a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2011, 13:40
  3. Audi 1.8T AEB engine oil light displayed on dash.
    By K7ERG in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2008, 16:45
  4. Fixed dead coilpack - engine mgmt light still on?
    By Mikebabs1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th December 2007, 20:41
  5. Engine mgmt light and car shuddering
    Last Post: 23rd December 2007, 18:07
