Volks AutosChris Nott
Results 1 to 36 of 36
Like Tree3Likes
  • 1 Post By pinterovski
  • 1 Post By box500
  • 1 Post By S3Alex
Thread: New loba/sachs clutch fitted
    Feb 2013
    262
    so had the new clutch fitted on Saturday , it's the loba smf kit and was fitted by JBS in chesterfield who were very efficient as usual
    I'm planning on running the clutch in properly as I read this is needed although if anyone knows the guidelines I'd like to hear them? I've not let it boost at all and was planning on driving this way for 500 miles or so, should I be careful not to rev to high also or is this not important?
    The clutch is much heavier than I had expected considering people's views on here, compared to the stock clutch which had no weight at all this thing feels a little too heavy if I'm honest although I am getting used to it, also the point of engagement has moved up, I'd say it bites quite high now, does the stiff feeling ease up any while bedding in or is this how it will stay?
    On the plus side I'm pleasantly suprised by the chatter emitted at idle (so far anyway as I've heard it gets worse)
    There's hardly any noise usually although it seems to vary, also I don't notice vibration too much, it kind of gives the illusion that the exhaust is a little more boomy on the overrun between 2&3k revs but I think that is the clutch noise, anyway it's not intrusive - well so far anyway!
    Audi S3 : revo stage 2+
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    277
    No it'll stay that stiff but you'll get used to it. Same way I felt after fitting a sachs to mine after the comments i'd read on here.
    Feb 2013
    262
    Oh that sucks then! anyone know what kind of life these kits can stand up too? will launches and qtr mile be okay and will it last?
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    829
    Quote Originally Posted by R34nel View Post
    As far as the Sachs goes, I have the organic+DMF and it is much heavier than OEM and yes the bite is higher, but after a week im well used to it. As far as bedding in, no idea on a method for this or if it is needed. Im just trying to keep below 3500rpm for a few hundered miles. Dunno if that's right or wrong or if I should even care.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Jonse's Avatar
    Oct 2012
    353
    Yeah ive had mine for around 1.5k miles and still stiff. I let mine bed in for the 1st 1k miles and now it pulls like a train. The one down side i do get chatter and its sounds the same as my mates diesel on idle but ive found if you let clutch out slow it doesn't make the sound.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    277
    It will be fine for the task but won't take lots of repeated full bore standing starts.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    your smf loba/sachs kit should be able to take some punishment.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    I got told by Statllers to drive as you would normally. But if you do standing starts/quarter mile drag races avoid them for a few hundred miles. But you can use full boost straight away as your only using the clutch when changing gears or slipping it to set off. I still went 200miles before really giving it the beans though. Just to be safe. Got about 1.5k also and clutch is still heavy. Although I don't notice it anymore, well after the first few days.
    Feb 2013
    262
    Thanks for your opinions on this guys, I think I will still baby the clutch for a while just to be on the safe side, a little confused as to why people on here have said that the clutch is only slightly heavier than stock though when I'd say it's about four times heavier, well I don't know about other people's but my oem clutch was properly light!
    Jul 2011
    Bucks
    161
    Same here, I was expecting the sachs clutch to be just like the oem (i.e. a namby pamby thing). It turns out it is a bit more "meatier" and the biting point is much higher. A couple of months in and I'm starting to get used to it, mainly by starting off in first gear with a few hundred revs more than normal.
    pinterovski's Avatar
    Oct 2010
    661
    Add pinterovski on Facebook
    On the first day i fitted my Loba/Sachs setup. Running in was about 130 miles
    and then pedal to the metal :P
    wuta3 likes this.
    Black roof,Tinted windows,Solar Orange Calipers,KW V3 Coilovers,
    HEKO Wind Deflectors,CAI ITG Maxogen,Non Res Supersprint Exhaust CB with custom Fi76mm DP,
    RevD with GFB DV+,Autotech HPFP,Custom SKN map Stage2,Forge ShortShifter,THS mounts,
    Twintercooler,Clutch is now on LOBA/SACHS!!!
    18 OZ Ultraleggera!
    365HP and 500NM of torque!
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    lol you got engine management light on :D
    Jul 2011
    Bucks
    161
    Quote Originally Posted by S. View Post
    My engine management light was on until a porsche boxster tried to race with me
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    Quote Originally Posted by box500 View Post
    hahaha cool :D
    was he surprised?
    Jul 2011
    Bucks
    161
    hahaha cool :D
    was he surprised?
    I think so !
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    yeah stage 2+ s3 is a great little rocket. i know that my has surprised few people...
    Jul 2011
    Bucks
    161
    I'm just at stage 2 Revo at the moment. Car deffo needs more power though. I feel a need for over 400bhp coming along..
    wuta3 likes this.
    Feb 2013
    262
    Well I'm 160 miles into having the new clutch and have done my weekly commute in it and it was a bit unpleasant if I'm honest, some junctions on steep hills and lots of stop start and it's a bit uncomfortable with the extra weight and high biting point, funnily enough it's only the 'chatter' that doesn't bother me at all. I'm going to bear with it obviously and I've been driving like my grandma so I'm yet to see what it's like when giving it some
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,772
    Admittedly,mine isn't a Loba,but I've had the Sachs before the current monster clutch,andI'd say the Sachs is marginally heavier than stock,and my current Spec is pretty much the same weight as stock.
    Any new clutch takes a little bit of getting used to,but you will find it copes with higher torque way better than the original piece of cheese did.
    Feb 2013
    262
    this is massively heavier than stock, I was in traffic earlier today at some lights, I was in 1st with the clutch dipped for about a minute or two and it was starting to make my leg ache, it not to heavy to push down or anything like that but it is a bit uncomfortable for steady daily driving, it wouldn't bother me if it was just a weekend or track car but it's used as a family car, I was under the impression the clutch upgrade would give a little more weight and some feel as my stock clutch was little harder to press down than the accelerator pedal!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,772
    That does sound odd.....it shouldn't be massively heavier,and I would take it back and get it checked out.
    wuta3's Avatar
    Jul 2012
    829
    Yea either you have the legs of a girl or that's too firm. For me it was noticable when first using, but now it feels fine as I adjusted. It is heavier, and still feels it, but not problematic.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,772
    Quote Originally Posted by wuta3 View Post
    My Sachs was never that heavy,and the Spec system has surprised both me and the guys at AMDTuning by how light it is in use,so I can't see any reason why the Loba/Sachs should be heavy,especially when lots of other users have no issues with it.
    The best time to take it back is immediately after,and at least be sure there's nothing wrong.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Agreed. Mines heavy too. Infact all the people who's got it says it heavy, but like said, after a few days it becomes the norm. I don't even notice it now unless I drive someone else's car. Or take mine back to Audi and get a courtesy car from them, but even with the stock clutch mine felt heavy. Now it would feel like I'd be trying to put my foot threw a wall I imagine as I'm yet to do this (take my car into Audi after the new clutch was fitted).
    Feb 2013
    262
    I'm wondering if some of the stock setups were heavier due to the fact that there were two different ones wasnt there, and the later ones were said to be stronger.
    I drive a few different vehicles and a van at work which all feel really light compared to this and maybe that's why I'm noticing it so much because every time I get back in the s3 I'm thinking this feels unpleasant compared to what I've just been driving, but I can say that it is a huge difference from stock, tbh the stock s3 clutch was lighter than any car I've driven in recent years, I've come from a couple of astra vxrs which I would say have a lovely weight to them and as a bonus the stock setup will take plenty of tourque and is not required to upgrade until 400lbs probably
    Feb 2013
    262
    little update on this, it seems to have got drastically lighter a couple days ago, so it's either loosening up with use or it's down to the outside temps suddenly getting warmer here, it was around 6c last week then the day before yesterday I noticed it felt great to use and it was 17c, aside from that I can't think of much else, it feels what I'd consider to be normal now although its certainly not light, I've only put about 180 miles on this new setup
  28. #27
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,772
    Maybe as you say,it's just loosened up a bit.
    Hope you continue to like it.
  29. #28
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    277
    I'd say your left has gotten stiffer rather than the clutch getting softer. Mine is certainly no softer than it was when it was fitted 5 months ago.
  30. #29
    ramp1990's Avatar
    Jun 2012
    81
    My clutch is heavy i dont know what a standard s3 clutch feels like, how would you tell if its been changed, without looking at it, the car has been tuned before by the looks missed engine cover mountings etc, (intake) i got in my misses ford focus 1.6 ebony and i pressed the clutch down nearly put my foot through the floor then couldnt acually lift my foot of the clutch to take off very strange feeling ha
  31. #30
    Feb 2013
    262
    Quote Originally Posted by bmh.01 View Post
    I can't imagine the use of the clutch has strengthened my already respectable thighs lol but as you say maybe I'm used to it
  32. #31
    Feb 2013
    262
    Quote Originally Posted by ramp1990 View Post
    My standard clutch was really mushy and light, had no feel to it, would maybe be slightly heavier than a focus but not so much that you would notice it
  33. #32
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    I was exactly the same when I drove another car after the loba/Sachs set up. It felt like I wasn't pressing the clutch in when I started to let off so that it would bite. Ha
  34. #33
    Feb 2013
    262
    At least it's good to know the loba will hold up though, I read this on their website
    'Although this clutch kit is rated at 550Nm, this is conservative. We have cars runing upto 700Nm on this set up.'
    That's 516lbs :-)
  35. #34
    ramp1990's Avatar
    Jun 2012
    81
    no no mines real heavy id say 3 or 4 times heavyer, hmm wonder if its had a clutch would be nice ha how would u find out?? lol
  36. #35
    Feb 2013
    262
    aside from opening up and looking all you can do is tune it and see if it holds out I suppose, or contact prev owner from logbook and ask them
  37. #36
    Jonse's Avatar
    Oct 2012
    353
    yeah reading back through this i would say your getting use to the clutch. Mine is still heavy. I let my friend drive mine yesterday and he couldnt believe how heavy it was, but to me it feels fine i dont notice it at all now
  1. loba sach clutch + smf - noise issue
    By z1mma in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2012, 21:48
  2. New clutch fitting problem
    By Nathanh393 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2011, 20:21
  3. H&Rs, Sachs Clutch and Denso Iridium Plugs fitted...car transformed!...
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2010, 13:50
  4. Sachs Clutch fitted + Dogbone Mount
    By Maz in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2009, 11:04
  5. Free Fitting on Sachs Clutches from AmD Essex.
    By shaun@amdessex.com in forum News & Latest Offers
    Last Post: 9th September 2008, 16:30
