Ok Guys,
Finally there is a proper serious brake upgrade available for the A3! The ECS kit uses a Porsche Cayenne 6 piston caliper, mounted DIRECT to the wheel hub, therefore removing the need for aluminium brackets, and fitting over a massive 352mm 2-piece disc. The discs are available in slotted and drilled, or just slotted. The kit contains everything you will need for the installation including high grade brake fluid!
The kit price will be £1450+vat, which is still cheaper than alot of other manufacturers kits which use the 993T caliper! This kit really is fantastic and you will NOT be outbraked! Calipers are available in Red, Black, Yellow, Blue and Silver.
Email richard@jbrperformance.co.uk for more details!
Rich
Rich
