Results 1 to 11 of 11
    Sep 2012
    16
    Angry Audi A3 2.0 FSI 2004 - Management light and MPH 1???
    Hi All, Here is my issue - My younger brother has just purchased an Audi A3 2.0 Fsi (Without me!) He took it for a test drive and all seemed fine, FSH, one owner etc. He has just drove it back to Birmingham from Leicester and after about 20 miles on the Motorway the engine management light came on and a light stating MPH 1? He says it seem to drive fine but obviously this is of concern! Any suggestions Please.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,468
    ​Have you run a vcds scan on the car?
    Sep 2012
    16
    No not as yet! He has literally purchased it about 1hr half ago.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,468
    Quote Originally Posted by Eazyd View Post
    try get a vcds scan done asap to see if it throws up any faults
    Sep 2012
    16
    Will do! Just wanted to see if it was a common fault!
    Jan 2012
    1,837
    Could you post a picture of the MPH1 thing?
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    The mph1 could be the speed alarm that you can set by pulling or pushing the button on the instrument cluster when you are moving at a speed. Basically if you drive at 30mph and pull or push the button on the cluster it sets it and then when you go over 30mph it beeps to tell you your going faster than you wanted. I think this resets its self once the engine has been turned off.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Jan 2012
    1,837
    Ah yes, correct.
    Speed warning, doh!
    The EML will need investigation though
    Sep 2012
    16
    Cheers guys!
    Sep 2012
    16
    Hi Guys, Used my mates cheap vagcom codes came up: 18711, 16688, 16684... Any suggestions?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,468
  1. MPG AUDI A3 1.6 FSI 2004
    By FINEST_A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st August 2012, 18:31
  2. HELP!!audi a3 tdi 140bhp diesel!engine managment light
    By audi_a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2011, 13:40
  3. Engine Management Light and Misfire - 2004 1.8T
    By dalespitfire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2010, 12:48
  4. Engine management light and ESP light on
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2005, 14:30
