Volks AutosEM Tuning
Results 1 to 8 of 8
    Jun 2010
    221
    After off Fans & Cooling
    Seems the fans are a common issue with the 8P models with a fair bit of information however the issues I have read aren't quite what I am having so apologies if there is a thread I have missed.
    Car is S3 (2007.5) 8P1, fans are not running after the car is off. Whether how long they run or not I can't even remember.
    No errors coming up through VCDS as well.
    Could someone give me a quick run down of common issues. Assuming relays are working, control unit I am guessing working alright as well.
    Thanks.
    Jul 2011
    217
    The fans won't come on unless you have been thrashing it and engine is still super hot. But you shouldn't be turning the engine off if you have been thrashing it unless you have taken it easy the last few miles from home as it will cause problems later
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by jonny1985 View Post
    This.
    If you're fans do kick in after you turn the car of you need to re-consider your warm up/cool down procedure. Any turbo car should be treated like this, infact it's good practice to do it with all cars.
    Jun 2010
    221
    Always let my car heat up and cool down if I give it a bit of a beating.
    Just interesting as never stay on after car is turned off.
    You have to remember I am in Sydney as well. Climate is a lot lot hotter. Not even in summer 30+ (Celsius) days did it come on after ign off
    Jul 2011
    217
    the cooling system is working perfectly or maybe stat or fan issues
    Jun 2010
    221
    thinking some sort of fan issue as the cooling system is fine at present. Just curious how often peoplesl fans run as i never hear mine, and as i said our climate is a lot hotter than yours.. (summer 30s+ .. just to rub it in lol)
    TDI140's Avatar
    May 2011
    1,356
    Always allow car to reach operating temprature before abusing it, by operating temp i mean check the oil temp not the coolant and radiator temprature, then when turbong off sit in the car and count to 25 then switch off its not hard or just get a FMIC lol
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,072
    Quote Originally Posted by TDI140 View Post
    (a) Turbong ... that sounds amazing
    (b) Yea my fans never continue whiirrring after ignition off, I had a golf that kept its fans on for like 1 min after ingition off.,
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
  1. 2.7t after run fan question
    By audi-a6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th June 2012, 00:15
  2. after run fan question
    By audi-a6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2012, 10:06
  3. Main fans running after switch off
    By jbcalvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2011, 21:25
  4. Cooling fans,not turning off
    By evocos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2010, 15:29
  5. NewTurbo Fitted, possible after-run fan problem?
    By alex-qts in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 14:19
