Volks AutosChris Nott
Like Tree1Likes
  • 1 Post By KrAzY K
Thread: key fobs don`t work to unlock/lock
    Apr 2013
    yorkshire
    11
    a3 1.9tdi 2006
    the 2nd key fob that is only used now and again the battery went flat ,i changed the battery and it didnt work,so not too bothered as it unlock`s the car and starts it off the key then yesterday the battery of the other fob died so changed the battery and it wont work.I tried the varies youtube videos and suggestions from similar threads on vag key syncing but none of them worked.
    Is it because none of the fobs are in sync with the locking system ?
    do i need to visit the stealers to sort this out?
    Oct 2012
    LEEDS
    81
    Hi
    Am not sure if youve fixed the problem. but have you used this method: how to program a vw, seat, audi coded key, when new battery fitted, or recoding new key. - YouTube
    Dean_T likes this.
    ''With great power comes Great RESPONSIBILITY'' - Spidermans Uncle
    Mar 2011
    Cleveland
    979
    That's long-winded! The A3 handbook says press unlock on the key, put it in the ignition, turn ignition on then off, remove the key and press unlock again....
    Oops! Didn't realise the thread was an old one.
  1. Key fob will not lock or unlock
    By m.c. in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2013, 20:53
  2. unlock button on key fob not working after reconecting car battery
    By jonnyb289 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2012, 08:56
  3. Key Fob problem - Not locking or unlocking
    By a3tazza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2012, 01:16
  4. Key fob doesn't work - options on re-coding??
    By VAGMAN2 in forum General Technical / How To
    Last Post: 12th June 2010, 19:37
  5. Key Fob Just Stopped Working Lock/Unlock not working
    By tomgreen78 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2010, 23:53
