JMB RetrofitsVolks Autos
    Jan 2013
    2.0 TFSI PRESSURE RELEASE VALVE PART No 06F129101N
    Hi
    Just wanted to know if anybody else has had to change theirs. Apparently its a common fault the diaphram splits and causes a loss in boost! Cost £30.00 for the new part which has been improved and £15.00 for the gasket from the stealership.20 minutes job to change.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,032
    Quote Originally Posted by REDNERRAW72 View Post
    Hi
    Googles the PN ...
    Yea that's the PCV aint it? Mine went, caused rough idle etc. Not sure it causes boost loss tho .... My DV went tho and that caused boost issues.... not the same part tho .. are u sure that's the right part number? You might mean the DV which has a later revision (rev D) ... that splits and causes boost issues.
    The rev D diverter valve is 06H145710D
    Confused.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Jan 2013
    Hi thanks for that!!Audi wakefield told me it was the part i have changed to fix problem but scanned again and it happened after i changed the part so will be getting this part that you have told me now!Many thanks
    wuta3's Avatar
    Jul 2012
    1,032
    Dont go spending money on my advice! Get a specialist to locate the problem first.
  1. Question for a plumber - pressure reducing valve
    By Geordie Mike in forum General Chat
    Last Post: 16th August 2008, 18:18
  2. brake pressure release solenoid
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2008, 10:34
  3. Diverter valve part number
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd November 2007, 08:29
  4. A3 Oil Pressure Relief Valve
    By prodrive in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2005, 13:17
  5. Boost pressure control valve
    By imported_SYNAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2004, 09:33
