Volks AutosBadger5
Results 1 to 10 of 10
Thread: A\C Noises
    Aug 2004
    An der sud Koste
    711
    A\\C Noises
    A couple of us have noticed we get funny noises from the a\c when warming up, knocking and ticking noises, almost like something is expanding. Usually only does it from cold and then disappears. Always done it since day one.
    Is this normal, does everyone get them?
    Cheers. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Dec 2004
    Chester
    247
    Re: A\\C Noises
    No, nothing on the two A3's I have owned, both quiet as a mouse on the A/C front
    mandyray's Avatar
    Sep 2005
    London
    189
    Re: A\\C Noises
    So far I haven't noticed any noises from the A/C but my previous car used to do this a lot (206GTi).
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Re: A\\C Noises
    No noises coming from the A/C but,now that the weather is getting cold,I have noticed it's performance is poor compared with my previous A4.
    My A3 mists up far more readily.
    stratos's Avatar
    Aug 2005
    Yorkshire
    69
    Re: A\\C Noises
    [ QUOTE ]
    [/ QUOTE ]
    Dont know about the A3 but my Passat has gone from a similar ticking to a chugging sound. Apparently it is the flap which seals the air flow when you switch to "recirculate" which expands when warm and shrinks when cold. It is fitted with a cog mechanism which causes a clicking sound when it tries to move the flap or check its position. Something in the Passat has tipped it over the edge and now it just makes a constant "chug-chug-chug" sound ALL THE TIME.
    I would suggest you get it checked if its causing you concern...Total dash removal on the Passat just to replace the flap/cog combo (2quid for parts, couple of hundred for labour) [img]/ubbthreads/images/graemlins/mad.gif[/img]
    Aug 2004
    An der sud Koste
    711
    Re: A\\C Noises
    Thanks for that. Mine just chugs when cold so guess it is just expanding and contracting.
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    Re: A\\C Noises
    My Sportback does it as well. You hear a faint clicking from somewhere in the dash.
    previously LeeS3
    On the wirral...
    393
    Re: A\\C Noises
    yep me too when cold..
    Jan 2005
    cambs uk
    1,139
    Re: A\\C Noises
    [ QUOTE ]
    [/ QUOTE ]
    yup, mine is poor at demisting, only noticed this week when the winter finally hit!
    also get a strange ticking sound, comes from the passenger footwell?
    May 2004
    10
    Re: A\\C Noises
    I get the same sounds coming from the dashboard. When I turn the heat up (about 23-24 c) I hear the noises. Sounds like the dashboard or something else is expanding due to heat.
    Hope is nothing serious.
