Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Lewbo
Thread: S3 MFSW to FBMFSW - Weird Problem?!
    May 2013
    Manchester
    33
    Hi All,
    I have been a 'viewer' and read many threads here over the years. I really hope somebody can help...
    I have a 56/2007 Audi S3 that had the normal multi function steering wheel. I purchased a FBMFSW (including the airbag) from a 2010 S3, everything fitted in fine and there are no warning lights on the instrument cluster. However, the buttons on the steering wheel do not light up nor do they work.
    I've had a look at the original airbag and wiring loom that came out of the car and it is 8J0 971 589 Q.
    I thought it was supposed to be a straight forward fit? I don't know the part number for the wiring loom that came with the FBMFSW as that is now in the car but I presume it would be the correct one?
    Can anybody help? (I have cruise control too, specc'd from the factory)
    Thanks in advance.
    May 2013
    Manchester
    33
    Could it be the fuse? As it looks like I'm getting no power at all.
    I might just put the original steering wheel back in and make sure everything still works...
    Mar 2011
    Cleveland
    993
    Coding maybe?
    May 2013
    Manchester
    33
    My car already had a MFSW, so it shouldn't need coding?
    Also, I would still expect power and lights to the buttons if it was a coding issue.
    Mar 2011
    Cleveland
    993
    Had to code mine when I changed it.
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    If you already had MFSW that worked correctly then I won't need coding as its already done and I have done this myself in the past. On my last a3 when I changed to FBMFSW I plug for the MF wast clipped in properly and they didn't light up or work so maybe give that a try that's only reason i could think of.
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    May 2013
    Manchester
    33
    Quote Originally Posted by a3_sline_tdi View Post
    Ok I'm going to take it apart now and will take a look again - thanks!
    May 2013
    Manchester
    33
    Just thought I would this thread, a3_sline_tdi was spot on, many thanks!
    I took the wheel apart, made sure everything was connected tightly and voila!
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    No problem mate glad you got it sorted.
    realstig likes this.
    Current
    previous
    May 2013
    Manchester
    33
    The other thing I've noticed is the steering wheel isn't straight any more, on a straight road I have to turn it to the left. I made sure I put it back on exactly straight and before I changed the SW, it was exactly straight i.e. tracking wasn't required.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    when you fitted it back on did you see where the little notch is on the slip ring that shows you the centre of the steering angle?
    you may need to do a steering angle reset in vcds if not
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    May 2013
    Manchester
    33
    Quote Originally Posted by Ash187 View Post
    Yeah I made sure the little notch and the middle of the steering wheel lined up perfectly. Will a steering angle reset physically alter the alignment of the steering wheel?
    Is there anybody in the Manchester / North Manchester area who has vcds?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    The numpties at ATS Camden (London) tried to track my wheels after i first fitted the 19s and said they couldnt do it. I drove into the place with the steering wheel perfectly straight and they returned it back with it at a 45 degree to the left. took it to Elite a couple days later who straightened up the tracking but the car still thought that it needed the steering wheel to be 45 degrees to the left in order to go straight... did a steering angle reset there and then and it straightened up the wheel perfectly.
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    May 2013
    Manchester
    33
    That's interesting to say the least! Is it fairly straight forward to do the reset?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    its a bit of a procedure actually, there is a full ross tech guide on it... have a look here for the info
    VW Golf (1K) Steering Assist - Ross-Tech Wiki
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    May 2013
    Manchester
    33
    Wow...I don't think I'm going to be able to do that. Looks like I need to find somebody who can do it for me.
    Any takers? I'll contribute towards the service
    Oct 2012
    Warrington, North West
    986
    I'm in Warrington if you don't find anybody closer
    May 2013
    Manchester
    33
    Quote Originally Posted by Mikemc View Post
    Thanks, I'm going to get the wheel alignment done this week. If that doesn't fix it, i'll be in touch
    Oct 2012
    986
    Cool, I'm off work all this week with a knee injury so pretty much anytime is good
    May 2013
    Manchester
    33
    Ok, its booked in for Friday afternoon. Will keep you posted.
  1. Couple of weird problems
    By X7YLE in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2009, 14:49
  2. Weird Problem, Please Help Me!!
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2009, 11:37
  3. MFSW to FBMFSW
    By N8 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2008, 13:49
  4. weird problem NOT FIRE-ING
    By vw754 in forum Diesel forum
    Last Post: 6th April 2007, 20:28
  5. WEIRD PROBLEM NOT FIRE-ING
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2007, 11:02
Tags for this Thread
