JMB RetrofitsSky Insurance
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By davc
Thread: Abs fault?
    Sep 2012
    85
    Abs fault?
    Hi guys just had the vag com put on my 2007 s3 as my esp light come up on the dash saying ESP fault
    the codes that came up where
    brake pressure sensor (g201)
    abs control module 01316
    i can see this is going to be an expensive fix
    Jun 2011
    Greenock
    214
    I had that problem with my A3 1.6 fsi just as i got it from the garage, it may turn out expensive.
    i was told by the garage it was about £800 to replace the abs module, not sure what it would be like on an S3 though mate.
    Sep 2012
    85
    Just seen a company up in Nottingham that will rebuild it, and give it a life time warranty for 250 for a rebuild might give them a all tomorrow
    Jun 2011
    Greenock
    214
    Quote Originally Posted by Adamj View Post
    I would say that is worth it mate and its alot cheaper than new, and im sure will work just as well, cant go wrong with a lifetime warranty
    Oct 2012
    Warrington, North West
    986
    I had this few week ago, there's a repair kit available for 150
    Jun 2011
    Greenock
    214
    I was lucky i got mine through warranty, seems a good price for the repair kit, are they easy to fit?
    Tay
    May 2012
    Warrington
    366
    Have you tried to test whether the G201 sensor itself is faulty? I think there's a good amount of info on the ABS system for testing and calibration that you could try before taking the hit...
    Try this but just check that you use the guide for the controller version your car has installed:
    http://wiki.ross-tech.com/wiki/index...onics_(MK60EC1)
    Oct 2012
    986
    Quote Originally Posted by stuartm View Post
    No idea, mine was also done under warranty, I know its battery out, probably a guide on here or over on another forum. Apparently it effects alot of cars a quick google search shows how big it is of an issue
    davc's Avatar
    Foursprung Duck Technik
    Jan 2013
    Caledonia
    217
    That will be the ATE/Teves MK70 module then - what a load of gash they are.
    Give these guys a shout they can remanufacture these units. Replacement new units will only fail again over time.
    ATE ABS Pumps Modules
    stuartm likes this.
    MY'09 S3 Sportback |Gloss Black Mirrors |Buckets |Black Optiks |Open Sky |Light & Rain Sensor Pack |CH/LH Lights |RNS-E & No Highs No Lows it must be Bose |
  1. limp mode and abs fault
    By smith4130 in forum Diesel forum
    Last Post: 12th March 2007, 22:50
  2. ABS fault - vag com - purley/croydon area
    By Dracoro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th February 2007, 22:38
  3. ABS Fault Light...
    By JGrant1285 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd August 2006, 09:50
  4. ABS Fault 0 any ideas?
    By Wicked666 in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th August 2006, 07:18
  5. ABS fault - now i'm desperate!
    By imported_mc119856 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2005, 22:58
