    Jan 2013
    vcds Scan result
    Hi
    Coming home from a trip away i suddenly lost power so a great Audi sport.net member met me today and carried out a scan he is the result,having found the code number on ross teck wiki it says that check hoses pipes,turbo charger /diverter valve and special notes say when found in 2.0 tfsi check boost pressure control valve(N249)FOR CRACKED RUBBER DIAPHRAM.
    How much will this cost to sort out?
    All advice much appreciated!!
    1 Fault Found:
    000665 - Boost Pressure Regulation
    P0299 - 002 - Control Range Not Reached
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 83266 km
    Time Indication: 0
    Date: 2013.05.04
    Time: 12:50:12
    Freeze Frame:
    RPM: 2708 /min
    Load: 83.5 %
    Speed: 91.0 km/h
    Temperature: 78.0°C
    Temperature: 19.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.224 V
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 A HW: 8P0 035 192 A
    Component: RNS-E HIGH EU H70 0550
    Revision: 01S Serial number: AUZBZ7E0900924
    Coding: 0209111
    Shop #: WSC 01317 552 00000
    VCID: 2D549D94B40E3670BAA
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 54209 km
    Time Indication: 0
    Date: 2010.09.08
    Time: 18:58:32
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209111
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 54209 km
    Time Indication: 0
    Date: 2010.09.08
    Time: 18:58:32
    Lewis583's Avatar
    Mar 2010
    829
    Well, do you have a 2.0tfsi or not?
    The N249 is fitted to the turbocharger compressor housing. It is held in with 3 allen head bolts (can't remember what size (5/6mm springs to mind)) The earlier type N249 valve had a rubber diaphragm and is prone to splitting, as the Ross-tech fault code description eludes to, when they get some age on them.
    The valve has been revised and now uses a piston type design which has proven to be more reliable. Couldn't say on price though bud.
    On the 2.0TFSi engines, it has been known for the PCV valve to fail which in turn causes a boost leak etc.
    Regardless of engine, you should check all boost pipe work for signs of leakage. Usually signs of oil around a joint is an indicator of a leak.
    Going on the Nav fault codes, you have a RNSE fitted? If yes, it hasn't been coded to the car correctly/at all. Will require coding via VCDS.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jan 2013
    Hi Lewis
    Yes has a 2005 55 plate 2.0 tfsi S-line mileage now 51940 FSH and yes do have RNSE it was fitted at factory according the the handbook/Bill for car.
    Lewis583's Avatar
    Mar 2010
    829
    RNSE was fitted from factory, but it could well at some point had that RNSE stolen/broken and replaced with another that wasn't coded to the vehicle.
    Start by checking boost pipe work for leaks then mate. If they look good, then I would remove the N249 valve and check the diaphragm.
    Full VCDS
    Jan 2013
    Thanks lewis
    Im taking to someone on friday who carried out cam belt change for me.
    Anthony
  1. Is it normal for a VCDS scan to take this long?
    By AndyMac in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th July 2010, 14:27
  2. VCDS scans - B6
    By slepy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2010, 20:15
  3. Haglos' VAG-COM Scan Results
    By Caesium in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2009, 00:01
  4. My First VCDS Scan
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2009, 22:23
  5. vag-com abs scan results, couple of questions.....
    By darby7 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th July 2005, 11:47
