EM TuningSky Insurance
    Aug 2012
    Bradford
    140
    Visit S3 syc's Instagram Channel
    audi s3 8p window problem??????????
    Just recently ive come out to my car and both windows have been all the way down,at 1st i thought i might have leant on the key but definatley not this time. has anybody else ever had this problem?
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Only issue I get with mine is the drivers side, if you use the button in car and pull up twice to auto raise fully, it does then stops and lowers a inch of two. Works ok manually.
    Feb 2013
    32
    Quote Originally Posted by coreythorny View Post
    You need to reset the auto function. Raise the window all the way up. Let go of the switch then pull it up again and hold for 2/3 seconds and that should be it.
    May 2014
    10
    Tried this several times with no luck ;((( didn't realise how often I use this feature until now!
    MEddy78's Avatar
    May 2014
    Surrey / West London
    21
    Does the glass go up / down ok? No stiff or impeded travel?
    Krony's Avatar
    Apr 2014
    Lincoln
    33
    I get a similar problem very occasionally when i close both front windows at the same time in auto, sometimes the passenger window will come back down about 3-4 inches.
    Audi S3 Ice Metallic Silver [2009]
  1. Audi S3 Window Problem
    By deep89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2012, 20:47
  2. Audi A3 electric window problems
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2010, 20:49
  3. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
  4. Driver side window problems
    By audia4t99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2004, 18:31
  5. Passenger Window Problem
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2004, 21:37
