Chris NottBadger5
Results 1 to 10 of 10
Thread: Quick question!
    Jan 2012
    51
    Quick question!
    Quick question as I'm proper confused lol.. I have searched but there's no definitive thread or explanation lol..
    what version of 8p bumper do I have? And also would the bumper below be a direct fit or we looking at new wings etc aswell?
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,547
    8p2 car ,if its a 8p2 bumper it will fit ,should have a part number on it ..
    Mar 2012
    278
    You have an 8P2 SLine front bumper. The other bumper that you've attached is off an 8P2 S3. Yes it will fit without replacing bonnets and wings, but you'll need to do a small modification to the impact bar that lays behind the bumper (you need to trim a small section off the bottom corners - this is covered in other threads if you want more details but it's easy enough to do).... You'll also need an S3 grille if that bumper doesn't come with one. The 8P2 A3 grille is slightly bigger than the 8P2 S3 grille, so unfortunately you wont be able to use your current grille
    Jan 2012
    51
    Damn and here was me thinking the grill would swap over lol! So I take it it's the 8p3 bumper that would need the wings and bonnet replaced then?
    And thanks for your help guys
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Quote Originally Posted by Darylaas View Post
    Yes, as well as headlights, grills and some other bits.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Lewbo's Avatar
    Aug 2009
    Hull
    1,045
    The Black S3 Style FK grill fits the S3 bumper as its shorter but still fits all other 8p2 bumpers like the s3 grill does.
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Did I read in another thread that FK don't do an S3 sized grill?
    Lewbo's Avatar
    Aug 2009
    Hull
    1,045
    They say it doesn't fit S3 but In actual fact it's shorter than the standard and s line grills, leaves a little gap at bottom of the bumper. My mate bought one to try on his S3 and it fitted.
    Current
    previous
    Mar 2012
    278
    Quote Originally Posted by a3_sline_tdi View Post
    Interesting, thanks for correcting me
    My car is in the bodyshop at the moment having the 8P2 S3 bumper fitted. I went and bought a genuine black optics S3 grille because I was told on here that my current FK S3 style grille wouldn't fit my new S3 bumper. Damn!
    The FK grille left a slightly larger gap between the grille and bonnet on my A3. I wonder if that's because, as you say, the FK grille is slightly smaller than the standard A3 grilles?
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    424
    You got a picture by any chance of it on the S3 and the "gap" in question?
  1. Quick Question about Aircon/Climate Control
    By DelBoyUK in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2004, 17:37
  2. A quick question on N75??? Valve
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2004, 21:31
  3. quick question
    By richy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2004, 10:46
  4. Quick Question
    By cbass in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2004, 16:42
  5. Quick question about Audi a4 coilover kit
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2003, 22:13
