Chris NottSky Insurance
Results 1 to 11 of 11
    Aug 2009
    833
    Haldex Gearbox and rear diff oil?
    I have an 04reg 3.2 V6 A3 on 55k miles
    My service manual says change the Haldex Oil at 60k miles so therefore in all its years it has never been changed.
    I have inherited the car from my mum who has had it from new and now spending my time fixing it up.
    The gear box has a faint whine and i mean faint as you got to be doing low speeds in the lower gears to hear it. It is also bit clunky when you change gears and dont get the clutch perfect (i have found this car to be very jolty on clutches for an oem one, almost as strong as the race clutch i had in my tin top.) but doesn't seem too bad.
    What would you guys suggest I do with the oils , it hasn't been driven that fast. But I want to make sure it is properly fixed up. My mum puts a lot of trust in audi and since her dealer told her not to bother servicing it at 2 and half year mark as shed only done 12k miles I am a little concerned to her local dealers upkeep.
    Apr 2013
    Aberdeenshire
    585
    Quote Originally Posted by Nutkin View Post
    It sounds like your car could do with a software update mine was very jerky and had a rough idle and would not hold 2000 rpm and would jerk when the car was moving with that engine it is also possible your throttle body is dirty.
    The Haldex should have its oil and filter changed at 40 k the gearbox oil is for life but that said I am away to do my at 36 k my Haldex has been done its easy.
    The Haldex is the rear diff and the gearbox shares its oil with the transfer box
    i would have you car scanned with vcds my car did my head in for months when I bought it.
    Jun 2011
    Great Melton Norfolk
    1,340
    Get the Haldex Oil and filter changed,should be done every 40k
    Aug 2009
    833
    Quote Originally Posted by Chillout View Post
    I have full VCDS myself so on top of that not a single fault.
    Ill get haldex and filter done then. Confuses me that the manual says 60K yet everyone else says 40K and a few select peoples say 20K !
    Any recommendations as to the kit i need etc?
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    842
    Also interested in the required bits for haldex oil/filter change ...
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Apr 2013
    Aberdeenshire
    585
    If you google bills web space r32 you will find a guide I just bought the oil from vw with my vin no the might give you a syringe with oil or just a litre container I used a pump like the ones found on a hand pump to fill it my Haldex filter cover was a hex but I think some use a special tool.
    my car had no fault codes either but ran rough also I would check if your car has had the coil packs done under recall if affected mine were done before I bought the car.
    Aug 2009
    833
    recall has been done how much fluid does the haldex take?
    Jun 2011
    125
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    Sep 2012
    Cape Town
    37
    I lifted these pics from one or other site. Hope this helps.
    Double J's Avatar
    Jun 2012
    London
    49
    Is Haldex first 60k then every 40k?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,160
    Always every 40k
  1. Gearbox and rear diff oil change s3
    By Daniel Thomson in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2011, 21:05
  2. which Gearbox and rear diff oil for 1.8T Quattro
    By Rhencullen1989 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th August 2011, 23:34
  3. Gearbox and rear diff oil grade's and quantity's.
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th March 2011, 23:56
  4. gearbox and rear diff oils
    By the911kid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2011, 15:12
  5. Gearbox and Rear diff oil
    By rolo tomassi in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2009, 21:52
