Badger5Monster Motorsport
Results 1 to 8 of 8
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Nightmare of a day
    Finally fitted my H&R springs.
    Then found I had a bulb out, drivers sidelight infact. I have LEDs from Trups, so pulled it out and the light itself fell into the headlight as I pulled it out.
    Managed to fish it out with some wire and sticky tape through the DRL light (pre-facelift Bi-xenons)
    Tested and worked fine.
    Put it all back together, headlights on. Now the other sidelight and Xenon didn't work.
    Turns out my battery had died as it would turn over.
    Jump started and all worked fine.
    However; now the Drivers sidelight, the one which fell in the light isn't working again. I presume it's working loose in the holder. Has anyone else had this problem?
    Also, I noticed on idle I get a little "blip" every now and again. No ticking at high rpm though.
    Smelt my oil and it smelt of petrol sounds like cam follower.
    What's the worse this can cause and what extent can it get to?
    My cars a 2008 S3 8P Pre-facelift.
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,553
    Hi mate ,id change the cam follower asap,any reciepts in audi folder to see when it was lasted changed?
    Mar 2013
    Leicestershire
    425
    I'll have a look when I get home.
    I do have a years Audi Approved warranty but will they refuse the work due to the lowering springs now? No chance ill take them off any time soon lol.
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,553
    Id get them to check cam follower ,lights and battery ..
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by RS3-KEL View Post
    will the spring only void relatable parts? Suspension, wheels etc
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    If you've fitted springs then you should be capable of checking the cam follower yourself, its a ten minute job. I bet its fine and you've just got a bit of car hypocondria because of the other problems you've had.
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by bmh.01 View Post
    Quite possibly, is oil smelling of petrol normal regardless then? I wouldn't say it was nose stripping strong.
    There's no fuel smell outside?
    Mar 2013
    Leicestershire
    425
    Here's the car lowered also :D
  1. Audi S3, 2 days of ownership, complete nightmare!!
    By criztal in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2012, 12:46
  2. nightmare of a day
    By rich164h in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2008, 17:31
  3. My Nightmare New Car Delivery Day
    By MushroomMan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2006, 06:32
  4. Essex RR Day Nightmare - Bhp Problems Resolved by AmD
    By Ade_D in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2005, 10:41
  5. Donnington Track Day
    By Joshie in forum Major UK Events
    Last Post: 27th February 2003, 19:07
