Chris NottVolks Autos
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By Dannykn9
  • 1 Post By SPARTAN91
Thread: Definitive Answer - Has a 2007 2.0 TDI sport 140 got a DPF ?
    Apr 2013
    26
    Hi all, I recently joined your superb forum to look up information as I am hoping to buy an A3. I have now looked at over 10 cars ranging from 2005 to 2008 cars, both 1.9 TDI's and 2.0 TDI's. I think I have settled on a late 2007 2.0 TDI 140 but after spending many hours searching on here I am unable to determine if it will have a DPF fitted? I do know that my neighbours 60 plate A3 SE definitely has one as he has had trouble with it, and I also know that his road tax is only £30 a year as I have looked at his tax disc. So given that the road tax on the 57 plate 2.0 Sport that I am thinking about is £140 a year does that give me any clues that due to the emissions being different that is may or may not have the dreaded DPF fitted ? Any help would appreciated. Many Thanks..
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,928
    my 07 had 1
    Apr 2013
    26
    Thanks Bez1001.. I did read somewhere on here that all 170's had DPF, was yours a 170 or a 140? Also does anyone know how I can visibly check for a DPF when I look at the car or what the definitive answer is regarding the 140 sport ? Thanks All..
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Look inside your engine compartment near or on the rh wheel arch. There should be a sticker with the engine type. Mine is a BKD which is the earlier 16v engine without the DPF. Was pleased to find that out! BMM are 8v with DPF. Think there is also a sticker in the spare wheel compartment.
    After 3 BMWs in over 13 years, I'm giving Audi a go.
    Apr 2013
    26
    Quote Originally Posted by BoutTime View Post
    Exactly what I wanted to know.. I have just looked at the HPI report that I did and the engine number is also BKD, so I guess that means it hasn't got a DPF? Great news that. Lets just hope the car is still available and I can secure the deal.. Thanks again.
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Look on the audi a3 wiki. All explained there. Cheers.
    Apr 2013
    26
    Thanks... Could anyone point me at the wiki, not obvious where to find it.. Thanks again.
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Quote Originally Posted by Andyc567 View Post
    http://en.m.wikipedia.org/wiki/Audi_A3
    Apr 2013
    26
    Still non the wiser... Googled, searched every forum und the sun, still can't find out if a BKD engine (2007) has a DPF.. Some must know, surely ?? Thanks.
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Andy have you read the Wiki I sent you the link for? It clearly shows the BKD is 16v and the later BMM is 8v with DPF. It's pretty clear mate, unless I'm missing something obvious.
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Check your option codes on sticker in wheel well and use this to decode VW Group Option Codes Decoder
    But I think you'll find you don't have one
    or Call your local Audi centre and give them your chassis number and they will be able to tell you
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Definate answer = NO
    All 140PD (upto late 2008 models pre facelift) DO NOT have a DPF. 140CR engines (late 2008 onwards, facelift models) do have a DPF. All 170 models PD and CR have a DPF.
    So the 07 140PD BKD you are looking at has no DPF.
    Hope this helps mate.
    martinivw likes this.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    c_w
    1,047
    my 07 had 1
    Very doubtful, unless it was actually a 170 of course.
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    403
    Easy answer for that year of 140 is NO DPF
    Oct 2013
    Sheffield
    my 07 bkd sport doesn't have one
  1. Newbie 55 plate a3 tdi sport 140
    By andy1acars in forum The Welcome Section
    Last Post: 24th March 2011, 14:44
  2. TDI Sport 140 - Remote Central Locking Failure?
    By Lucefer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2005, 15:11
  3. A3 TDI Sport 140 - quick question about oil ...
    Last Post: 26th April 2005, 09:20
  4. A3 2.0 TDI Sport 140 - 220+ AmD Technik
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2005, 21:48
  5. A3 2.0 TDI Sport (140) questions
    By bazzer in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2003, 20:58
